Insulating A Cement Basement.... - Insulation - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 10:06 AM   #1
Insulating a Cement Basement....
Hi all,
Am looking for suggestions on how to insulate a cement basement properly. The house is post war 1950s, 700 sq feet. Its very cold in the winter, so am replacing the windows next month. What are your thoughts on using Rigid Foam board directly on the cement walls and even floors?
Lisa
Lisa66 is offline   Reply With Quote
Old 04-18-2011, 11:01 AM   #2
Basements are complex due to the potential risk from damp.
It may require tanking first.
A good option is the insulated plaster board products which are available as these would help with the walls and also consider fitting a floating insulated floor.
Mark Russell is offline   Reply With Quote
Old 04-18-2011, 11:27 AM   #3
Insulation in CANADA!
Thank you Mark, I appreciate your reply!
Old 04-19-2011, 01:03 AM   #4
Registered User
Rewards Points: 5,204
Welcome to the forum! I hope you don't mind, I moved you to "Insulation" for better/faster responses.....
Foam board on concrete walls is good; http://www.buildingscience.com/docum...ent-insulation
The value of foam below grade; http://www.quadlock.com/technical_li...Insulation.pdf
You would also air seal the drywall, pressure treated bottom plate (if used), no air space between different insulation, sill sealer under plate for thermal/capillary break, foam board and canned foam the rims, etc. Check with your local B.D. for approval; http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part2.html
And; http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part3.html
Be careful with fiberglass; The "biggest loser" in fiberglass insulation....
Read up and we can then help with any questions…….
Gary
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
insulating duct work in basement Master Brian HVAC 10 05-19-2009 11:28 AM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 07:31 AM
