-   Insulation (http://www.diychatroom.com/f103/)
-   -   insulating cathedral ceiling (http://www.diychatroom.com/f103/insulating-cathedral-ceiling-100209/)
South Branch Ca 03-31-2011 08:52 PM
Building a new house and trying to determine the best way to insulate the cathedral ceilings. This will be 12-12 pitch using a manufactured truss with knee walls in the loft.
One option is to spray 10 inches of closed cell spray foam insulation onto the under side of the roof sheeting with out an air baffle and no ridge vent, then put the tongue and groove on. (recommended by building inspector and insulation contractor) expensive
Next option is to use an air baffle and ridge vent, put up the tongue and groove pine on the ceiling leaving a gap at the top and then blow insulation down into the cavity. Pushing the hose all the way to the bottom and fill as the hose is removed. (recommended by different insulation contractor) ceapest but can not be certain all the cavity will be filled
Another option is use an air baffle with ridge vent, spray 2-3 inches of closed cell spray foam insulation then use fiberglass insulation and place the tongue and groove on. (my thought on the best of both insulation options) middle of the road and possible best of both worlds
So my question is are any of these good options? Pro's/con's to these. Am I missing something here, are there other options I haven't listed?
Gary in WA 04-02-2011 09:48 PM
Find your Zone on the map or closest City below the map; http://publicecodes.citation.com/ico...001_par001.htm
What is required for R-value? http://publicecodes.citation.com/ico..._11_sec002.htm
Gary
South Branch Ca 04-03-2011 10:47 AM
I would be in zone 5A, walls require R-20 and ceilings R-49. I have a quote of $4000 just for the ceilings with 10 inches of spray foam on 1,200 sq ft. foot print with 12-12 pitch cathedral ceiling. Kinda pricey and that's with out an air baffle. My concern with out the air baffle my shingles won't last as long due to the higher heat they will experience. I see alot of homes in this area getting new roofs put on that are 15 years old or less. Some may have went with cheap shingles but the Architectural shingles typicaly are a 25-30yr and these are being replaced as well.
I like the spray foam cause it will seal all the tiny cracks that fiberglass doesn't but the cost is quite high. That's why I was thinking if I could use an air baffle, 2 inches of spray foam then put up fiberglass. Unless there is a better idea or I'm missing something. Also would I need to use a vapor barrier or just use fiberglass with vapor barrier backing?
tcleve4911 04-03-2011 11:33 AM
Spray foam
Question....did YOU tell the foam guy you wanted the cavity filled to 10" or did HE recommend it?
10" sounds excessive...that's like an R 60
I believe the rule of thumb is 1" foam = R6
Typically 4-5" is used in cathedral ceilings.
http://t2.gstatic.com/images?q=tbn:A...xZGYKc_1QC41o0
I'd call another spray foam company and get another price.
Also find out what R value is recommended in your area and get a foam price for that.
South Branch Ca 04-03-2011 01:45 PM
That was recommended by the insulation contractor who gave me a bid. My area requires R-49 in the ceilings. Is there a maxium thickness that can be sprayed? Would there be a problem if the area between the foam and the dry wall wasn't filled. Say there is 12 inches between the roof sheeting and the dry wall and they spray in 10 inches would the 2 inch void create a problem?
Red Squirrel 04-03-2011 03:49 PM
If that area won't be accessible at all, I say go all the way with R60. It might hurt the wallet now, but it will pay off in the long run.
I'm just wondering if it's ok to not have any air circulation at all, I guess if there is no place for air to even exist, it's not an issue, I guess. I'm guessing it will come flush with the end of the studs, and drywall is going over that?
While you are there consider all forms of lighting/electrical so you can run that wiring now. Ceiling lighting, fans, etc. "while we're here" usually ends up costing more then what you expected though. :P
tcleve4911 04-03-2011 04:41 PM
No problem...it's done all the time....
http://i172.photobucket.com/albums/w...lection311.jpg
http://i172.photobucket.com/albums/w...ddition005.jpg
http://i172.photobucket.com/albums/w...ddition004.jpg
South Branch Ca 04-04-2011 10:17 AM
What about the air baffle between the roof sheeting and the spray foam. Should I use it or not?
tcleve4911 04-04-2011 10:18 AM
No baffle needed with closed cell foam
Gerry Hendry 09-26-2011 10:44 AM
insulate cathedral ceiling
In my area 6 3/4 in is R40.
Windows on Wash 09-26-2011 11:41 AM
In 2lb foam, that would be correct.
1/2 lb foam will be closer to 20-24 depending on what number you use.
AGWhitehouse 09-26-2011 12:07 PM
Closed cell foam should be installed with maximum of 2" lifts. Lifting more than 2" in a single pass can cause an exothermic reaction within the foam and damage the closed-cells and greatly reduce the effective R-value. People have actually died from "over-spraying" and having the excessive heat from the exothermic reaction cause the foam to burst into flame.
ccarlisle 09-26-2011 01:04 PM
The OP seems to be evaluating the merits of a 'vented' vs an 'unvented' roof and seems to have both options open to him...in most cases, a roof will tend be easier either to vent or not to vent depending on the shape and structure of it. With a vaulted ceiling and knee-walls, he has the option of both.
But in Zone 5a, the question of a vapour retarder comes into it; and for convenience, I'd go with an unvented roof, with 7.5" of closed-cell foam, no baffles - but I'd throw in something the OP perhaps hasn't considered: consider a thermal break i.e. a 2" XPS foam board on the inside. Not only will this meet your R49 code, but will provide that thermal break.
Other options for an unvented roof involve adding something to the exterior of the roof, like XPS or iso-panels, but we're not sure you're needing that.
Gerry Hendry 09-27-2011 03:39 PM
cathedral ceiling insulation
My installer says 5 in is plenty(R30) in cathedral as opposed to R 49 in flat roof.
AGWhitehouse 09-27-2011 04:22 PM
Be careful when adding 2" XPS to the interior wall face along with partial closed cell spray foam fill. Both are, in the thicknesses mentioned, class II vapor retarders, and when a void left it creates a double barrier assembly with the potential for trapping unwanted moisture.
If 2" XPS or Polyiso foam in used as an interior sheathing beneath the wall board then open cell foam or un-faced batt insulation should be used for the bay fill to ensure any moisture within the wall system can dry to the exterior of the system.
