Insulating A Brick House - Insulation - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 05:54 PM   #1
insulating a brick house
do i need to insulate a double brick home? if so why?
gdarlene2 is offline   Reply With Quote
Old 02-28-2012, 09:31 PM   #2
Rewards Points: 370
Do you need to? no, because you can spend your money on heating it instead.
Will it help you save money on heating? yes. There is value in insulating a home.
MLMIB is offline   Reply With Quote
Old 02-28-2012, 10:07 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
Darlene -
Where are you located? If it was 3 layers (wythes), I would suspect some typical residential construction in England or possibly Russia.
What do you mean about a "double brick" wall? Two layers with a gap of some size between them or is it a solid bonded wall?
Dick
concretemasonry is online now   Reply With Quote
Old 02-29-2012, 10:08 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,228
Need more information in this case.
Changing the venting of a brick wall improperly can have disastrous consequences.
Please help!! Old brick house brandi_lea Building & Construction 32 01-21-2011 07:02 PM
opening for a new window for old brick house vote4Pedro Building & Construction 5 01-18-2011 06:37 AM
House wrap over insulating foam board or under?? getn2old Building & Construction 7 07-28-2010 10:53 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Attaching pergola to brick veneer house Mikedks Building & Construction 4 12-28-2008 12:01 PM
