Insulating Bonus Room Roof - Insulation - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 12:04 PM   #1
Alright, newbie here. I was planning on this being a pretty straight-forward project until I got in the bonus room and started looking around. I'd like to finish off the space and was planning on using baffles stapled to the sheathing and then placing fiberglass on top of that to vent it to the ridge vent. One problem ... my modular home company built two sections of the roof pieces (the front one and the rear one) with horizontal rafters meaning I can't place the baffles to vent it vertically to the ridge vent.
Any suggestions for handling horizontal rafters? On each side of the sections with the horizontal rafters are vertical rafters where I could vent to the ridge vent, could I vent horizontally then drill some holes?
I could post a picture if that would help ....
Any pointers are appreciated. Thanks.
Mike
m6465 is offline   Reply With Quote
Old 08-23-2011, 10:25 AM   #2
AGWhitehouse's Avatar
Originally Posted by m6465 View Post
I could post a picture if that would help....
Yep...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-23-2011, 01:09 PM   #3
You can see from these pictures that the center section has horizontal rafters, with vertical rafters on either side. The front of the house is fine because there is a dormer with a window and I have vertical rafters leading to the ridge vent. Picture one shows the middle section with a glimpse of both sides, picture two is a close up of the right side.
Insulating Bonus Room Roof-picture-1.jpg   Insulating Bonus Room Roof-picture-2.jpg
Old 08-23-2011, 02:09 PM   #4
You can put the baffles in the vertical rafters to the right, but the center section will need to be a "hot roof". Just fill the bays with insulation.
Old 08-25-2011, 12:51 AM   #5
Holy cow, those only look like 2x4's coming up the roof angle, and then 2x6 on the horizontal! Now, my size perception is terrible, but still.
What area of the country is this in?
Is there insulation in the floor for rest of the house, or what is in the ceiling here is really what the whole house gets?
There is a method of insulating the roof deck with out venting, making the whole attic part of the conditioned zone, which would apply in this situation. Possibly skip the venting and benefit more from that extra insulation.
Usually includes using the silver radiant barrier and shingles colored lightly for less heat gain issues, and using spray foam for maximum R-value when you have such little space.
But you may live in a temperate zone and don't need much insulation.
heybales is offline   Reply With Quote
Flooring options in lower floor bonus room Trustmemalawyer Flooring 11 06-08-2011 01:27 PM
Finishing Bonus Room; Adding Ductwork stevenriz HVAC 1 05-15-2011 07:15 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
