Insulating Beside Basement Stairs. - Insulation - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 10:49 PM   #1
Rewards Points: 2,210
Insulating Beside basement stairs.
IN all the information on insulating basements I have not seen any information on the best way to insulate beside basement stairs when doing reno's.
Above the stairs we usually used 1" styrofaom and 1X3 strapping then Drywall. Comes out to 1&3/4" which just covers the stringer on the stairs usually. The spray foam it to the stringer.
Under the stinger we did the old 2x4 wall and fibreglass which is no longer recommended. Now I would do the 2" styro and then the 2x4 wall, Fiberglass insulation and no poly.
I guess you could rebuild the stairs say 2" narrower or whatever you can if they were wide enough and you still had 36" wall to wall when you were done.
There are metal Z shaped strips that you can attach to the wall then put your 2" Styrofoam in-between. Would be 2.5 inches when drywalled.
mae-ling is offline   Reply With Quote
Old 01-12-2012, 11:53 PM   #2
Just found this. There is also insulation with metal strip embedded in it. Probably hard to get in my area.
Old 01-15-2012, 09:13 AM   #3
Remodeling Contractor
I use drill and fill method to insulate the walls along a stairway. A 2 9/6" hole is drilled in the middle of the wall in every stud bay. Then either dense packed cellulose or Retro-Foam is injected into the cavity. The hole is then plugged with a foam plug set back 1/8". 20 lb hot mix compound is applied over plug. Air sealing with spray foam is a critical step along any openings in the wall or risers. The risers are usually covered with 2" polyisocyanurate foam board with seams taped and perimeter spray foamed.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Water leaking down outside concrete basement stairs handlethis Building & Construction 3 08-06-2010 04:49 PM
Need Advice on how to complete basement stairs. Bakuto Building & Construction 11 04-05-2010 10:37 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
