Insulating Behind Bathtub Access Panel - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Gary in WA
Old 01-04-2017, 02:07 PM   #1
Rewards Points: 32
Question
Insulating behind bathtub access panel
1950s brick ranch in Ohio
We have a room on the north side of the house that gets cold in winter. We have to keep the door shut, which is part of the problem. We put plastic up on the windows but that only helps so much.
There's a large access panel going to the adjacent bathroom, and that air space goes straight to a cold room in the basement, so I would like to insulate it. The access panel door is just a thin piece of wood paneling.
Do I just stick a thick piece of rigid foam insulation on the access panel door?
Could I fill the square gap to the basement with fiberglass insulation, or will that get wet from the pipes and cause mold?
Thanks in advance!
Insulating behind bathtub access panel-img_4037.jpg   Insulating behind bathtub access panel-img_4038.jpg
brian0918 is offline   Reply With Quote
Old 01-04-2017, 03:40 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Re: Insulating behind bathtub access panel
My only concern would be if you stop roomside heat from getting down in that space, what is keeping those pipes above freezing at that point?
Old 01-04-2017, 03:48 PM   #3
Rewards Points: 32
Well, the basement is finished and partially conditioned at least. It's not freezing cold down there, but not warm either.
Old 01-04-2017, 04:30 PM   #4
Rewards Points: 424
Consider doing a smoke stick test to check naturally occurring cold/warm air flow currents and then determine where and what will be needed as insulation, vapor barrier etc.
Old 01-04-2017, 08:59 PM   #5
Registered User
Rewards Points: 4,912
----------------------Welcome to the forums!-----------------------------
That open chase to below should be closed off with rated plywood or other fire blocking because your floor fire blocking has been compromised;
"Openings around vents, ducts, pipes & cables at ceilings & floor" pp. 4; http://www.codecheck.com/cc/ccimages...CB3_sample.pdf
Add some closed cell pipe insulation to the pipes under the plywood level, seal with sheet metal around the pipes after adding plywood, fire-caulk the remaining smaller gaps. No insulation above the floor unless trying to keep the warm tub water warm...
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Jim F (01-05-2017)
Old 01-05-2017, 01:55 AM   #6
Rewards Points: 424
Insulating pipes in this situation has no value.
Old 01-05-2017, 06:24 PM   #7
Registered User
I was going by "and that air space goes straight to a cold room in the basement," and this; basement is finished and partially conditioned at least. It's not freezing cold down there, but not warm either.' If the basement room never gets to freezing, at least insulating the hot water supply below the floor will keep it from losing heat- especially if the water heater is a distance away and the room below is unconditioned- storage room or such. Smoke pencil is not needed, with the opening left open -- the stack effect will add basement air to above. Same with a fire or fumes... close it off- if just for fire-blocking- same with a crawl space.
Gary
Old 01-05-2017, 10:48 PM   #8
Rewards Points: 32
Thanks for the replies. Was the sheet metal layer intended as a vapor barrier, and does it go on the basement side, or the first floor side? I'm thinking first floor side, since that's warmer.
Old 01-06-2017, 01:03 PM   #9
Registered User
Yes, the side you are working from. It is easier to cut tighter fit with metal then wood, than you won't even need FR foam, but use caulking there. Also, put a bead around/under the metal on the wood to stop air.
Hot water is 120* (or so) and cavity is at 60* or so, a 60*F difference,,, if you had that temp difference between exterior/interior; would you insulate your walls/ceiling/floor? The warmer the HW is in the pipe, the less money it costs you, especially if the supply run is long.
Also, cc foam wrap stops/muffles sound. Most houses you can hear the water running through at least one wall area. If you insulated all water supply lines- conditioned spaces also- it would be much quieter. Add the pipe hold-downs over the insulation to the studs and stop direct sound through the wood to drywall in stud cavity there. I use FG batt in that interior cavity (pipes present and main drain line from upstairs so you don't hear the toilet flush- running joke on Archie Bunker show.
Gary
brian0918 likes this.
brian0918 (01-06-2017)
Old 01-12-2017, 02:12 AM   #10
Rewards Points: 14
Good try.
BryanWeaver is offline   Reply With Quote
Need Help With Ideas for Cutting Access Panel In Fiberglass Tub martowski Plumbing 9 12-09-2014 10:15 PM
Installing a cat flap/pet access door on a standard interior panel door? GordCooper Remodeling 7 03-08-2012 10:02 PM
Bathtub Drain Stopper leaking, no access panel. How do i replace? noodle1979 Plumbing 3 01-01-2012 10:11 PM
Finishing off access door panel TanMan Building & Construction 12 02-05-2009 06:59 PM
