Insulating Basement Walls Question - Insulation - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 11:41 AM   #1
Just to give you a little back story, I purchased my home with a Full finished basement and bath. I then noticed water that pouring in after big rain storms. I decided to rip out all walls and framing. My question is do I have to insulate basement walls that are below grade next to the foundation? I have been told that I should use R19. The thing is, using a 2x4 framing construction and due to the space I need to put the framing I cannot fit R19. Is this a problem?
Thanks iN Advance
rhymlz is offline   Reply With Quote
Old 02-13-2012, 11:53 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
Walls should be insulated.
Fiberglass is a horrible option for basements and there are countless threads in here discussing the different approaches to basement insulation.
Where is the home located?
Old 02-13-2012, 12:01 PM   #3
I'm in Northern NJ. I had just spoke with my towns building inspector about the Rim Joist area and Rigid foam. He couldnt understand why I would use the rigid and told me to just use Fiberglas Batts in that area. Since he was so against the Rigid in the joists I figured I he would not like Rigid on the walls either. He also said the Rim Joist needed to be R19, would that also apply to the walls?
Old 02-13-2012, 12:01 PM   #4
Is insulating the walls code or is it just a preferred?
Old 02-13-2012, 12:47 PM   #5
Registered User
Rewards Points: 5,230
Teach him, gently.... Rims expand/contract with the seasons and humidity; http://www.buildingscience.com/docum...d-but-strange/
Fiberglass is excellent for furnace filters because it filters dirt. Great for finding air leaks in the attic because air blows right through it: http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Bad for rim insulation because air blows right through it to condense on the wood.....use foam board; http://www.buildingscience.com/docum...l_seal_rev.pdf
As per Code. Find the closest City near you below the map: http://publicecodes.citation.com/ico...001_par001.htm
Find the requirements: http://publicecodes.citation.com/ico..._11_sec002.htm
R-10 in foamboard or R-13 in other. Without the foamboard, you may likely have problems. Notice the different applications of below-grade insulation and the problems with each; http://www.buildingscience.com/docum...study-analysis
The basics in a nut-shell: http://www.buildingscience.com/docum...lation-systems
Of course, local AHJ have the final say.......
Gary
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
rhymlz (02-17-2012)
Old 02-17-2012, 05:22 PM   #6
If I put up 1" of xps can fiberglas touch it?
Old 02-17-2012, 07:36 PM   #7
Rewards Points: 768
spray foam and forget all of it....probably worth the effort of cutting precise pieces of foam board.
cibula11 is offline   Reply With Quote
Old 02-18-2012, 12:07 AM   #8
Registered User
It should touch the foamboard: http://joneakes.com/jons-fixit-database/743
Air gaps will give convective loops.
Gary
basement framing question, PT walls? brewcrew Building & Construction 2 08-27-2011 06:51 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Basement Insulation question tophercole Building & Construction 0 11-19-2009 10:01 AM
insulating basement walls partially below grade fixrite General DIY Discussions 8 03-06-2009 08:38 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
