Insulating Basement Walls - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 10:24 PM   #16
Registered User
Rewards Points: 526
Originally Posted by bryanp22 View Post
I'm in milwaukee area. So you do 1.5 rigid and then rolled in the walls? Do I need to worry about moisture at all with the rolled insulation if I do the 1.5" of rigid foam?
R-7.5 (1-1/2" of XPS) and R-13 will give f.b. temp of 38*F and 31%RH. If relative humidity is above 31% in the basement at 70*F, it could condense there. You need to realize that if the drywall is completely air-sealed; electrical outlets, caulking, f.b. under the bottom plate with a bead of caulk, rim joists air-sealed, rigid f.b. glued with compatible adhesive in 1' grid squares, cavity insulation touching f.b.- no air gaps at all, you will be fine; http://joneakes.com/jons-fixit-database/743
Basement vapor barrier; https://docs.google.com/viewer?a=v&q...fHFsk1RrK9G2HQ
http://www.buildingscience.com/docum...wall-approach/
Fire-stop every 10' per code.
Gary
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Insulating Basement Walls Question rhymlz Insulation 7 02-17-2012 11:07 PM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 06:19 AM
Insulating interior basement walls brazzle Insulation 3 05-04-2011 07:24 PM
Need opinions on insulation of basement walls mstemphoski Building & Construction 0 03-28-2011 10:15 AM
