Insulating Basement Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 09:08 PM   #1
Insulating basement walls
I am looking to finish my basement and was told to apply visqueen directly to the wall, and then cover with 2 inch foam board. Everything I read states to use the foam board but says nothing about using visqueen. My question is will the foam board be a good enough vapor barrier on the wall or should I use both visqueen and the foam? I am also concerned that visqueen will create mold, should I be?
Ntucker is offline   Reply With Quote
Old 12-19-2011, 09:14 PM   #2
AGWhitehouse's Avatar
Read the past posts within this forum. I personally have seen/typed the answer to this question multiple times...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Windows on Wash (12-20-2011)
Old 12-20-2011, 09:07 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,820
The vapor barrier (i.e. permanence) depends on the type of foam used, but it absolutely can serve both as an insulator and the vapor barrier.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 07:19 AM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 01:44 PM
Insulating interior basement walls brazzle Insulation 3 05-04-2011 08:24 PM
Need opinions on insulation of basement walls mstemphoski Building & Construction 0 03-28-2011 11:15 AM
