Insulating Basement Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 07:28 AM   #1
Insulating basement wall
I'm in the process of renovating my basement. I have a block foundation, and I live in Northern Ontario, which means that the winter's get very cold and snowy and that the summers get very hot and humid. I plan in building standard walls and insulating with batt insulation. There seems to be a lot of controversy up here about whether to insulate right to the slab or to leave a gap for some heat to escape to help prevent frost problems. I'm hoping to get some more opinions on that to help with making a decision. Thanks!
alexlacelle is offline   Reply With Quote
Old 09-24-2012, 08:02 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,986
I would strongly recommend against fiberglass in this application.
Rigid foam is the way to go if you do not have any moisture infiltration issues.
There is zero comparison in the overall wall effectiveness and what the net improvement comparison will be.
Old 09-24-2012, 11:00 AM   #3
What do you think about Roxul? Code here says that there should be a moisture barrier behind the insulation (tar paper). I'm not sure how I would do this with rigid foam. Also, how would I run my wiring with rigid foam?
Code also apparently says that the insulation must be 15 inches above the finished floor, so I think I'm stuck with that... That being said, it also states that there must be a seal under the insulation at that point. I'm not sure what is considered a seal for that?
Old 09-24-2012, 01:33 PM   #4
Roxul is better than standard FG in this case.
Foam serves as your moisture and vapor barrier if it is the right type.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Load bearing basement wall? hyunelan2 Building & Construction 9 04-23-2012 11:36 PM
basement framing and insulating questions around ledge khatz Building & Construction 8 01-02-2012 12:50 PM
Basement wall insulating Alyson Building & Construction 5 12-03-2011 08:50 PM
Insulating Exhisting Basement Wall soasquad Building & Construction 3 01-10-2010 06:56 AM
