Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-30-2012, 12:03 AM   #1
I can do it......I think!
Send a message via Yahoo to MovedTooMuch
Insulating basement wall with 1" furring strips??
I have a basement that was previously finished with 1" furring strips, no insulation, and 1960's thin drywall panels. I tore off the old poor looking drywall and I would like to insulate the walls before I put back new drywall. I would like something flame resistant. All of the foam panels I see in the box stores are flammable.
The walls are concrete block on all four sides and I do have a fireplace in the room. None of the walls are below grade. There is no water penetration.
Q) Are there any good flame-resistant materials I could use for insulating the wall? What would you do?
P.S. I really don't want to yank off the 1" furring strips since there are FOUR door frames in that room and 2 of them are very close to the corners. I don't really have the room for 2x4 framing.
Thanks in advance.
Insulating basement wall with 1" furring strips??-006.jpg   Insulating basement wall with 1" furring strips??-002.jpg
MovedTooMuch is offline   Reply With Quote
Old 11-30-2012, 12:09 AM   #2
If your going to sheetrock over the wall so what if the foams flamable?
Most likly you have paper backed insulation in the rest of the house that's flamable. As long as there's rock over it your fine.
Sure would be better if you built a 2 X 4 wall instead, more insulation, could run wiring and make the room legal.
Old 11-30-2012, 12:15 AM   #3
So it would not be legal to have wiring in a wall with 1" furring strips? The current wall has wiring (but this is West Virginia and the codes are different here!).
Old 11-30-2012, 01:18 AM   #4
thin rigid board and sheet rock, like joe said. roxul is fire proof, and they MAY make insulation that thin; maybe drain board? Dunno, but if they make it, it would be fine for your application.
Old 11-30-2012, 11:55 PM   #5
Moderator
I'd use some R-max (foil-faced) between the strapping to cut the heat loss and save energy; http://www.quadlock.com/technical_li...Insulation.pdf
Even 3/4" f.b. would cut your heat loss by 70%: http://www.enersavesystems.com/pdf/E...Insulation.pdf
Be sure it is glued air-tight, no air allowed, and ADA the drywall: http://joneakes.com/jons-fixit-database/743
http://www.buildingscience.com/docum...wall-approach/
Gary
Clothes taking longer to dry?
Old 12-05-2012, 05:50 PM   #6
Is the room below grade? If so the energy loss isn't as great as above grade, because of the constant earth temperature.
@GBR - correct me if the above statement is wrong.
Thus if it were me I would get the 1/2" foam board cut it to fit between the furring strips then sheet rock over it. Depending on wall temps after that I would then use some 1/4" sheathing and install another layer of drywall. Just ensure it is all sealed up. With 1/2 board you have R3 and 1/4 sheathing you have R1 + two layers of drywall, 1/2" drywall is R .5, so R1. Only equals R5 but below grade is decent. However, I don't know if this meets Code in your area.
The bigger issue is what HVAC you want to use for heating and cooling, considering humidity and size.
rebelranger is offline   Reply With Quote
Old 12-06-2012, 08:41 AM   #7
Exterior Construction
Windows on Wash's Avatar
Energy loss will not be as great give the lessened temperature differential, however, insulation is still a must.
condensation behind vapor barrier of walkout basement wall fusion_ta66 Remodeling 10 08-01-2012 11:14 PM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Insulating existing basement wall tigereye Remodeling 1 12-28-2009 07:24 AM
