Insulating Basement Half Walls-my Plan - Insulation - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 07:52 PM   #1
insulating basement half walls-my plan
hi.
would this be an ok way to finish my basement walls?
-remove bag insulation
-attach 1 1/2" C-300 Extruded Polystyrene Rigid Insulation from floor to bottom of the 2x4 wall (this is about 6 feet up from floor)
-this 2x4 wall already has insulation in it with a plastic vapor barrier.
-it is also 1 1/2" out from the concrete foundation so the foam will fit perfectly
-tape and sprayfoam all gaps
-i will then put drywall over that
thanks in advance!
anthony777 is offline   Reply With Quote
Old 11-10-2011, 07:55 PM   #2
pics
Old 11-11-2011, 07:51 PM   #3
Registered User
Rewards Points: 5,460
Where are you located?
Gary
Old 11-11-2011, 09:28 PM   #4
Toronto, Canada
Old 11-15-2011, 09:39 PM   #5
Registered User
Fig.2-10 with a wood framed wall or fig. 2-11 with strapping, ask your local AHJ for guidance: http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part2.html
To confuse you further: http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part3.html
Some tests done in your location:
http://www.buildingscience.com/docum...ent-insulation
Gary
insulating basement walls Bavvy Building & Construction 1 10-07-2011 01:40 PM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 06:19 AM
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 08:54 AM
basement walls chuckofaltrades Painting 1 10-27-2009 09:51 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
