insulating basement half walls-my plan
hi.
would this be an ok way to finish my basement walls? -remove bag insulation -attach 1 1/2" C-300 Extruded Polystyrene Rigid Insulation from floor to bottom of the 2x4 wall (this is about 6 feet up from floor) -this 2x4 wall already has insulation in it with a plastic vapor barrier. -it is also 1 1/2" out from the concrete foundation so the foam will fit perfectly -tape and sprayfoam all gaps -i will then put drywall over that thanks in advance! |
pics
2 Attachment(s)
Where are you located?
Gary |
Toronto, Canada
Fig.2-10 with a wood framed wall or fig. 2-11 with strapping, ask your local AHJ for guidance: http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part2.html
To confuse you further: http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part3.html Some tests done in your location: http://www.buildingscience.com/docum...ent-insulation Gary |
| All times are GMT -4. The time now is 10:21 PM. |
