#1 |
insulating basement ceiling
I want to insulate my unfinished basement ceiling for the purpose of keeping my main room above floor warmer do i use faced or unfaced insulation if faced does the paper go toward the upstairs or face the basement also i live in illinois what r value and do i have to use one that specifically says ceiling?
#2 |
Exterior Construction
No need to insulated between conditioned spaces.
Spend the money on more aptly insulating the basement walls and air sealing. Insulation between conditioned spaces is only to help abate noise.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Average Joe/ex-Navy IC3
Also do not forget about air sealing around outlet boxes, windows, doors, attic hatches. Those are the largest heat & cooling loss culprits out there. Only time I would insulate the underside of a floor, is if it was over a crawlspace that is non-conditioned.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#4 |
Moderator
Treating the basement as unconditioned per code, find your zone here;http://publicecodes.cyberregs.com/ic..._11_par002.htm
Insulation for floors- per zone, here; http://publicecodes.cyberregs.com/ic..._11_sec002.htm Vapor retarder goes toward the warm side- up. If the basement is dry/drafty, you could cover the f.g. with a housewrap on the joist bottoms to stop air infiltration from degrading its R-value, treating it more like a crawl space; http://energy.gov/energysaver/articl...-insulate-home Keep in mind you may create problems with the plumbing/ducting uninsulated and colder without the heat loss from above warming them as it does now... Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| insulating basement ceiling-yes? no? Antimold on basement floor | canoes | Building & Construction | 1 | 01-31-2012 07:46 PM |
| Insulating Ceiling for a Basement Suite | vancouver_guy | General Discussion | 1 | 12-26-2010 09:00 AM |
| Drywalling my basement ceiling | luweee | Remodeling | 5 | 03-24-2009 07:58 PM |
| Insulating unfinshed basement ceiling for sound | daveyd | Building & Construction | 38 | 02-02-2009 11:57 AM |
| Basement Ceiling- Combo of Drywall and Drop ceiling? | H Thomas | Building & Construction | 5 | 03-27-2006 09:27 AM |
