-   Insulation (http://www.diychatroom.com/f103/)
-   -   insulating basement ceiling (http://www.diychatroom.com/f103/insulating-basement-ceiling-167910/)
djmack 12-31-2012 07:29 PM
I want to insulate my unfinished basement ceiling for the purpose of keeping my main room above floor warmer do i use faced or unfaced insulation if faced does the paper go toward the upstairs or face the basement also i live in illinois what r value and do i have to use one that specifically says ceiling?
Windows on Wash 12-31-2012 09:12 PM
No need to insulated between conditioned spaces.
Spend the money on more aptly insulating the basement walls and air sealing.
Insulation between conditioned spaces is only to help abate noise.
gregzoll 12-31-2012 10:37 PM
Also do not forget about air sealing around outlet boxes, windows, doors, attic hatches. Those are the largest heat & cooling loss culprits out there. Only time I would insulate the underside of a floor, is if it was over a crawlspace that is non-conditioned.
Gary in WA 12-31-2012 10:42 PM
Treating the basement as unconditioned per code, find your zone here;http://publicecodes.cyberregs.com/ic..._11_par002.htm
Insulation for floors- per zone, here; http://publicecodes.cyberregs.com/ic..._11_sec002.htm
Vapor retarder goes toward the warm side- up. If the basement is dry/drafty, you could cover the f.g. with a housewrap on the joist bottoms to stop air infiltration from degrading its R-value, treating it more like a crawl space; http://energy.gov/energysaver/articl...-insulate-home
Keep in mind you may create problems with the plumbing/ducting uninsulated and colder without the heat loss from above warming them as it does now...
Gary
