Insulating Basement Below Grade - Insulation - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 08:05 AM   #1
bryanp22's Avatar
Rewards Points: 290
Hi I'm finishing a room in my basement and am evaluating my options for insulating my cinder block walls that are below grade except for maybe the top 18 inches. Local code says no vapor barrier. Does that make my only options spray foam in the studs or xps glued to the block before framing? I am confused if xps will be considered a vapor barrier and cause me to fail inspection. If xps works is 1" or 2" necessary?
bryanp22 is online now   Reply With Quote
Old 05-15-2013, 10:32 PM   #2
Registered User
Rewards Points: 5,492
Vapor barriers, Class 1 (poly sheeting) are no longer required below grade in most of U.S., where are you located?
http://publicecodes.cyberregs.com/ic...001_par003.htm
http://publicecodes.cyberregs.com/ic...001_par005.htm
Depends on location for foam thickness to raise the dew-point temperature in the wall cavity, preventing condensation on the wood framing.
At 2" XPS is a vapor retarder; pp.3-5; http://www.buildingscience.com/docum...apor+retarders
Gary
Old 05-15-2013, 10:37 PM   #3
bryanp22's Avatar
Rewards Points: 290
I'm in milwaukee so zone 6. My basement is dry. Just looking to take appropriate precautions.
Old 05-16-2013, 09:46 AM   #4
Rewards Points: 89
Go with Roxul in between studs if you don't want to glue XPS to the walls,it gives a nice R-15 versus R-13 for fiberglass.No itch to it and very easy to cut and size.
Remember,if you put XPS on the walls,it must get covered,if it catches fire,it emits toxic gas that will kill you mighty dead.
spring3100 is offline   Reply With Quote
Old 05-16-2013, 11:33 AM   #5
bryanp22's Avatar
Rewards Points: 290
So if I use roxul I just frame next to cinder block and then add the roxul? Any idea on cost? I see Home Depot can special order but no cost is listed. Do I need to use treated studs then against the cinderblock if I don't use foam?
Old 05-16-2013, 01:37 PM   #6
Rewards Points: 89
Stand the studs off the wall so they arent in contact with it,say 1/2 to 3/4 of an inch.
If you are going to use it,Lowes has it in stock for 39.99 a bag.
I recently did about 100 lineal feet of basement wall 8 ft high and I think I used 9 bags.
Doesn't rot,decay,mold up and is Class A fire rated,good stuff.
Your bottom plates need to be pressure treated,additionally,they should have sill sealer (foam roll) stapled to the bottom,that way no wood is in contact with the floor.
Old 05-17-2013, 11:44 PM   #7
Registered User
Using 3 coldest months for you:http://www.weather.com/weather/wxcli...graph/USWI0455
an average of 25*F and room temp of 68*F, with; R-5 XPS/R-15 Roxul = safe to relative humidity of 30%RH
R-10/15 = 38%RH
R-15/15 = 45%RH
Work with the local AHJ on the stairs. Use PIC board insulation if needed. Roxul alone (no foamboard) will condense moisture on the CMU and back edges of framing; above grade/3' below grade areas at/above 40%RH basement air. You need to realize these levels are figured on 43*F (AVERAGE) temp for the concrete block inside face. So, any temperature below 25*F outside (for most of your coldest 3 months), you risk condensation from the indoor air in the winter, plus outside air in the summer; http://www.buildingscience.com/docum...lation-systems
http://www.buildingscience.com/docum...g-your-basment
Leaving any air gap between cavity (air-permeable; fiberglass, rock wool, etc.) insulation/CMU, insulation/drywall, or foamboard/CMU will give convective loops;http://joneakes.com/jons-fixit-database/743
https://docs.google.com/viewer?a=v&q...fHFsk1RrK9G2HQ
Gary
Old 05-18-2013, 12:23 PM   #8
Rewards Points: 89
I leave the studs off the wall,I push the Roxul against the wall,you can stuff Roxul between studs and wall also,rips into small pieces easily.
Old 05-19-2013, 08:41 PM   #9
Roxul makes boards that you put right up against the basement wall, and then you can do the framing. Link to video I have no experience with Roxul, just seems like this would be easier than doing studs first and then stuffing insulation behind them.
Rekonn is offline   Reply With Quote
Old 05-26-2013, 09:55 AM   #10
I do not believe xps would be considered a vapor barrier but call the local inspector to be sure.
1" should give you an R5 value and 2" should give you an R10 value, thats up to you.
Stcrosby is offline   Reply With Quote
Insulating Basement mabrown6 Insulation 12 03-18-2013 08:51 AM
Insulating Uneven Basement Wall Help (with pics) jefferyscott Building & Construction 3 02-01-2013 11:32 AM
Basement insulating and framing blakeasaurus Building & Construction 0 02-01-2011 06:37 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
