Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-14-2012, 02:12 AM   #1
Insulating Basement
I built my 2x4 walls in my basement 1 inch from the concrete wall and am about to insulate with Roxul, a batt type insulation which will sit nice and snug within my 16" centered studs. My question is whether I should push it towards the back of the wall so it touches the concrete or push it only as far so it's flush with the studs, thus leaving an air gap behind?
I solved any water penetrating problem from the outside by having a new weeping tile system installed and applying blue skin and insulating with R10(2" XPS from the footing to just below the grade. Although a problem I am having and thus hesitating on how I will place my R14(Roxul) insulation is that I have some very extreme cold spots that are generally in 1 corner on a painted surface above grade which I have lots of water condensing. I am going to spray foam these areas to help add R value along with the batt insulation but I am generally concerned with what will happen to any moisture that is going to be present between the concrete wall and my insulation in other areas if a -45 deg C week comes along in the future.
My studs have been sitting for months so they are dry by now and my basement is dry as well. I will be using a dehumidifier during the summer months and will be installing a vapour barrier before drywalling. Thanks in advance for helping.
danjag is offline   Reply With Quote
Old 01-14-2012, 08:39 AM   #2
Disabled wood vet
titanoman's Avatar
Insulating Basement
Flush it with the studs so you can staple the paper (barrier) to the inside front of the studs.
titanoman is offline   Reply With Quote
Old 01-14-2012, 11:23 AM   #3
Insulating Basement
My insulation is supposedly mold and moisture resistant but I don't want mold growing behind my insulation against the wall. So your saying to allow the space behind the insulation and allow the air to circulate?
Old 01-14-2012, 11:49 AM   #4
Disabled wood vet
titanoman's Avatar
Insulating Basement
I would think so.
I'm not sure if you need any type of a barrier over the concrete or not.
Old 01-14-2012, 07:03 PM   #5
Moderator
Insulating Basement
Where are you located?
No air gaps: http://joneakes.com/jons-fixit-database/743
Gary
Clothes taking longer to dry?
Old 01-15-2012, 04:31 PM   #6
Insulating Basement
I am located in Thunder Bay, Ontario, Canada.
I will place my mold and moisture resistant Roxul against the wall. Will the cold wall condense water behind the insulation if it's flush with the wall or will the insulation not allow for air to get into those areas and thus not cause water to condense?
I only have a few bad spots where the walls get extremely cold where it condenses and I plan on spray foarming those spots in addition to putting the Roxul
Old 01-15-2012, 07:00 PM   #7
Remodeling Contractor
Insulating Basement
you need at least 2" closed cell spray foam to keep the exterior wall warm enough to prevent condensation
Old 01-15-2012, 07:21 PM   #8
Insulating Basement
Although spray foam is a good idea t is not absolutely necessary, 2" foam board would work as well.
Do a search for basement insulation on this forum. It has been discussed a lot.
mae-ling is offline   Reply With Quote
Old 01-15-2012, 07:23 PM   #9
Insulating Basement
if the basement walls are straight and even enough. You do not want any space behind the foam board.
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Insulating my basement DanS281 Carpentry 1 08-28-2011 04:05 PM
Insulating unfinished basement, First time home owner please help! ashory Building & Construction 7 08-26-2011 12:44 AM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 07:19 AM
Insulating partial in-ground basement? HiccaBurp Building & Construction 6 10-25-2010 11:03 PM
