Insulating Attic Wall Shared With Living Space - Insulation - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 03:08 PM   #1
Rewards Points: 640
Insulating attic wall shared with living space
Try this again... tried to post this 5 times today every time it fails...
anyways..
I have a house constructed in 1996 which is 2 stories, and then it has a 1 story master suite which has attic space from a gabled attic that butts up against the house (standard gable attic, triangular ends against the houe and to the outside)
this wall that the attic butts against is not insulated, not sure why, but its not and of course its cold in the winter against that wall. the inside is completely finished and drywalled, the attic wall is just studds and you can see the inside drywall (2x4 studds in this part, nut sure why, the rest of the houe is all 2x6 *shrugs*)
I want to insulate this wall with roxul insulation to get a little more r-value then fiberglass, in addition to the sound deadening and increased firestopping you get with roxul.. but of course roxul has no vapor barrier
do I need a vapor barrier here? I assumed yes since its unconditioned attic space touching conditioned space, but then none of my ceilings have vapor barriers.. (I live near pittsburgh, pa so not sure what our region wants / requires)
if it does have to have a vapor barrier, what do you suggest? I don't want to go fiberglass, and cellulose would be in the same category as roxul for the vapor retarder
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 07-11-2012, 07:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Picture would be very helpful here, however, the general answer to your question would be no.
Vapor barriers are overused and largely unnecessary in most of the climate regions.
Old 07-13-2012, 12:04 AM   #3
Registered User
Rewards Points: 5,236
"do I need a vapor barrier here? I assumed yes since its unconditioned attic space touching conditioned space, but then none of my ceilings have vapor barriers.. (I live near pittsburgh, pa so not sure what our region wants / requires)"-------------------
You are in Zone 5, Fig.#3: http://www.buildingscience.com/docum...nd-wall-design
Gary
Adding Floor & Living Space to Attic Over Uneven Joists ziggy138 Building & Construction 18 02-06-2012 02:38 AM
Utility light in attic space sheslostcontrol Electrical 13 02-25-2011 01:40 PM
Insulating block exterior plumbing kitchen wall desrtrat Building & Construction 4 12-16-2010 07:51 PM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
