Insulating An Attached Garage - Insulation - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 05:42 PM   #1
Insulating an attached garage
My master bedroom is on top of my attached garage. It is very cold in the winter, and warm in the summer. I was wondering if insulating the garage would help. I believe the ceiling of the garage already has insulation (and I don't want to rip out the ceiling drywall). However, the walls of the garage do not have any insulation. Is it worth it to rip out the drywall and put insulation in the walls of the garage? Will that improve the temperature control in the garage, and therefore the master bedroom? I realize that there are multiple areas that may need improvement (new garage doors that don't leak air, new windows in the master bedroom), but for now, since I am going to have the garage painted, I was wondering if wall insulation will help.
Thank you!
CooperRex is offline   Reply With Quote
Old 03-08-2013, 05:54 PM   #2
Rewards Points: 13,960
Not going to help much.
Never once have I seen the propper amount of insulation over a garage, and just as often there was no air sealing done before it went up.
Old 03-08-2013, 06:36 PM   #3
Registered User
Rewards Points: 526
I agree with Joe, not help much, especially if you have a vehicle door or use it as a garage for parking. On top of that, if in a heating climate, the garage floor is right on the cold earth, and unheated. So your thermal barrier (insulation) is at the ceiling and gets cold from garage space cold air, similar to a crawlspace/earth, Fig. #7: http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Old 03-12-2013, 09:39 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,234
You can't treat it as a conditioned space if you have a car or any chemicals in there. The best way to to move the insulation layer to the garage ceiling. It isn't cheap though.
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Attached Garage, No sub panel, seperate grounding rod danocars Electrical 6 03-15-2010 05:27 PM
100 amp Attached Garage Sub Plan KevinBeamer Electrical 18 10-04-2009 08:11 AM
Attached Garage Construction in Northern Virginia Nova Building & Construction 5 07-29-2009 09:47 PM
