Insulating Around Windows - Insulation - DIY Chatroom Home Improvement Forum
Old 05-03-2014, 10:56 AM   #1
Rewards Points: 113
Insulating around windows
I want to use foam insulation around windows. Presently there is fiberglass. Can I foam over fiberglass? Is there any issue with moisture if I leave fiberglass? Thank you Tim
EFTHIM is offline   Reply With Quote
Old 05-03-2014, 02:09 PM   #2
Rewards Points: 6,652
Just use the DAP foam in the can. Cleans up with water. Fiberglass is not airtight. It will breathe just like we breathe. Mainly helps to keep dirt out of the house.
Old 05-09-2014, 01:48 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
No issue. Just push the fiberglass in so that you have adequate space for your foam.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-09-2014, 03:05 PM   #4
Rewards Points: 14,312
Compressed fiberglass has no insulation value. Remove it and use low expanding foam.
Old 05-09-2014, 05:00 PM   #5
You leave it in to act like filler foam. That way you are not using a whole can of foam to do two windows.
You want to just leave it in there. I did that with mine, when I went around and filled around the perimeters with the DAP foam in the can. Helped a lot doing it that way.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
HomeSealed (05-12-2014), Windows on Wash (05-11-2014)
Old 05-09-2014, 05:10 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,796
Youcan use the foam to seal gaps/cracks... but as Joe says, you don't want to pack the insulation, .... you actually loose insulation value if you do.....
Sometimes the small gaps between rough frame and window frame have been jam packed with insulation (probably by well intentioned but not well informed tradesmen).... I think that would be great to pull out and fill with the non-expanding foam.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 05-10-2014, 07:22 PM   #7
Registered User
Rewards Points: 526
R-13 insulation is just R-30, compressed.
From pp.41; http://www.huduser.org/Publications/pdf/walls.pdf
The density increases as you compress it, losing total R-value BUT gaining density (R-value) per inch; means better insulation. It is far from worthless- with no insulating value: think FG board insulation (on HVAC ducts);
"Common Name(s): Rigid fiberglass
R-value per Inch: 4.4
Strengths or Best Use: easy DIY installation, air can go around but not through this insulation, used for roof insulation (commercial) and foundation insulation, used in narrow cavities, not susceptible to moisture damage, naturally fire resistant (needs no additional chemicals)
Weaknesses: expensive, not available everywhere" From; http://www.insulation-guide.com/insulation-types.html
So as you compress fiberglass, it increases the density for better air stoppage/insulating qualities, but will never equal foam for air sealing; read a few pages-- http://books.google.com/books?id=a29...(1995)&f=false
Most people are aware that FG losses R-value when compressed, but fail to realize it gains R-value per inch of material installed. http://www.greenbuildingadvisor.com/...fiberglass.JPG
Just push it in more for room for the foam, you are not after the minimal R-value gains in the window/door perimeter (compared to over-all wall/ceiling/floor) but the air-stopping value of foam.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 05-11-2014, 10:41 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
It is exponentially more important to get the gap sealed than it is to insulate.
Get a good window and door foam and it will be close to an R-6 per inch. That small gap and compressed FG is not going to make the insulation schedule a poor performer.
Pushing the FG to the outside edge will also keep the foam from possibly expanding out and interfering with the siding if there is no housewrap.
The wall is already only an R-4 at best at that location (i.e. stud wall), compressed FG and foam are still far superior and I think there is less fudge potential if you leave the FG in there (i.e. as mentioned above).
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
gregzoll (05-11-2014), MTN REMODEL LLC (05-11-2014)
Old 05-11-2014, 07:55 PM   #9
Rewards Points: 548
Didn't read the whole thing. Sorry. But someone suggested packing the fiberglass in...and that can be a BAD idea toack too tightly because.....you can actually push the sides out of the window out of rack. Ron
ront02769 is offline   Reply With Quote
Old 05-12-2014, 09:06 AM   #10
Home Performance
HomeSealed's Avatar
Rewards Points: 712
well stated above... you are not looking for r-factor in a 1/8-1/4" gap around the perimeter of a window, you want a seal there. Push the fiberglass in an it acts as a backer rod for your foam. Do be careful though as ron stated not to over do it so far as to bow the side jambs in... If you want to pull the fg out, thats okay too, not a huge difference either way.
www.HomeSealed.com
Worthwhile to replace old wood frame basement windows with new vinyl windows? Cost? TomServo Windows and Doors 5 10-25-2012 07:10 AM
Insulating around windows with spray foam (low expanding) strategery Windows and Doors 8 10-05-2012 07:49 AM
Insulating these basement windows ffemt121 Insulation 14 10-03-2012 06:42 AM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
