Insulating Around In-Wall Heaters - Insulation - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 11:28 PM   #1
Hello,
I have two Cadet C202 electric heaters, one in our office and the other in living room. They are mounted in the wall. The depth of the heater wall can or guts for lack of better words are about 3 1/4". My studs are 2x4" (full 4" as the house was built in 1925).
The problem is they are mounted on outside walls so the insulation had to be removed to install them in the wall. My main concern is I can feel a light draft when I put my hand next to the heater grill (when they are turned off).
Does anyone have any creative advice for still putting some form of insulation behind them? Or, am I better off taking them out and either relocating or getting a better heater?
Thank you.
ruanddu is offline   Reply With Quote
Old 03-06-2012, 12:23 AM   #2
Rewards Points: 13,270
Never should have been installed in an outside wall, move them.
Old 03-06-2012, 12:59 AM   #3
Rewards Points: 1,092
I agree w/ Joe. You are sending dollars out the door 24-7. Plug the leaks and insulate.
Old 03-06-2012, 09:39 AM   #4
Thanks guys. I was afraid that was the answer.
Insulating an OSB sheated wall moon48 Insulation 1 06-22-2011 03:12 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Insulating block exterior plumbing kitchen wall desrtrat Building & Construction 4 12-16-2010 07:51 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 10:54 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
