Insulating Around Recessed Lighting - Insulation - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 08:29 PM   #1
In a little over my head
Rewards Points: 706
insulating around recessed lighting
How close do you like to trim R-30 fiberglass batts around recessed light cans? Insulating the top of the can seems like a bad idea to me. Or not? The cans are air-tight, insulation contact rated. Once the drywall is up, the attic will be inaccessible. The insulation is going up first.
I called OC. The nice girl suggested I use their premade tee-pees over the cans. But I don't think that should be necessary with IC rated cans.
ratherbefishing is offline   Reply With Quote
Old 12-18-2011, 10:11 PM   #2
Registered User
Rewards Points: 5,236
Is this a test??? Lol, they are insulation contact..... call the light mauf., if still worried. This may help if the walls aren't done yet because you've been talking with me........ http://www.advancedinsulationinc.com...Insulation.pdf
Gary
Old 12-18-2011, 10:45 PM   #3
Rewards Points: 706
Thanks, Gary. No. It's not a test. That article was a good one. I thought I'd done a pretty good job, and that reinforced it. I did my best to avoid gaps or unfilled spaces. Tomorrow morning I'll read it again. Then, the attic/ceiling. After that, another inspection!
This room is going to be the best insulated room in the house. By a lot. After I'm done with this, maybe I'll pull the top course of lap siding and blow cellulose between the blackboard and the drywall.
Old 12-18-2011, 10:46 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
IC fixtures we typically spray foam right over.
Non-ic, we create boxes around them.
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 12:23 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
insulating recessed lighting spiker Electrical 5 04-09-2009 11:21 PM
Insulating IC recessed lighting. topher0524 General DIY Discussions 4 02-10-2009 07:03 AM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
