-   Insulation (http://www.diychatroom.com/f103/)
-   -   insulating around recessed lighting (http://www.diychatroom.com/f103/insulating-around-recessed-lighting-126980/)
ratherbefishing 12-18-2011 08:29 PM
How close do you like to trim R-30 fiberglass batts around recessed light cans? Insulating the top of the can seems like a bad idea to me. Or not? The cans are air-tight, insulation contact rated. Once the drywall is up, the attic will be inaccessible. The insulation is going up first.
I called OC. The nice girl suggested I use their premade tee-pees over the cans. But I don't think that should be necessary with IC rated cans.
Gary in WA 12-18-2011 10:11 PM
Is this a test??? Lol, they are insulation contact..... call the light mauf., if still worried. This may help if the walls aren't done yet because you've been talking with me........ http://www.advancedinsulationinc.com...Insulation.pdf
Gary
ratherbefishing 12-18-2011 10:45 PM
Thanks, Gary. No. It's not a test. That article was a good one. I thought I'd done a pretty good job, and that reinforced it. I did my best to avoid gaps or unfilled spaces. Tomorrow morning I'll read it again. Then, the attic/ceiling. After that, another inspection!
This room is going to be the best insulated room in the house. By a lot. After I'm done with this, maybe I'll pull the top course of lap siding and blow cellulose between the blackboard and the drywall.
Windows on Wash 12-18-2011 10:46 PM
IC fixtures we typically spray foam right over.
Non-ic, we create boxes around them.
