Insulating Around A Fireplace Insert - Insulation - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 02:00 AM   #1
Rewards Points: 87
insulating around a fireplace insert
I am in the process of insulating my daylight basement in this manner:
However I am not sure what to do around my existing fireplace that will become a wood burning insert:
To the rear of the fireplace area is the garage. The orange block in my mockup represents the size of a suitable wood burning insert for my space, in this case a 'Pacific Energy - Vista Insert'.
The neon green areas represent the minimum clearances for combustible materials.
As I am insulating very well all along my walls with Foamular 150, I don't want any kind of a thermal break or short circuit around my wood burning insert/fireplace area.
Is a product such as this: http://www.unifrax.com/web/UnifraxHo...6?OpenDocument what I would use to fill in those areas between the fireplace insert and the existing cinder block as well as the clearance between where my XPS/furred wall will end?
Also, should rebuild my mantle a little so that the fireplace insert is flush with the level of where my furred wall will be rather than recessed?
hellonoko is offline   Reply With Quote
Old 03-05-2012, 08:49 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Roxul would be perfect in this case and is rated for those type of temperatures.
As long as the cavity is airtight, the offset between insulation and no insulation will be slight. You could improve the air tightness by sealing the CMU block as they are notorious for seeping air.
Tags
fireplace insert , insulation
Fireplace Insert Chimney Liner installation eric859 HVAC 11 03-04-2011 04:58 PM
Installing a fireplace insert in older home. Fixitgeorge Remodeling 4 02-02-2011 11:09 AM
Cold Air Coming In From Bottom/Underneath of Gas Fireplace Insert mark2741 HVAC 7 12-10-2010 10:05 PM
electric fireplace insert too small - cover/flange recommendations? cdnsupguy HVAC 2 11-18-2010 06:58 PM
Removing a pre-fab fireplace insert MarkinTN1 Remodeling 1 10-10-2009 12:20 AM
