Insulating 4 Season Deck Floor - Insulation - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 10:08 PM   #1
I am enclosing my deck to make a 4 season room, approx. 10x16. I live in Rhode Island so have a cold winter. My deck is only about 2 feet off the ground which is going to make it difficult to get under.
I have read people using fiberglass and foam insulation but I already have 1" Dow Rigid Foam insultion. What is the best way to apply this? Is the best way to cut sheets and insert between the joists and then fill in cracks with spray foam? Can I just nail the foam across the joists? No sure about that since I would have space between foam and floor. Do I need to apply anything else?
Last option I just read... can I apply on top of my current deck boards and then nail the plywood for my floor on top of that?
Any advice would be greatly appreciated.
maj0819 is offline   Reply With Quote
Old 03-25-2013, 11:22 PM   #2
Registered User
Rewards Points: 5,216
One way, fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Old 03-26-2013, 08:28 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
Pictures will be of a big help in this case.
I think you are better suited to get under the deck (if possible) and thermally uncouple the whole structure at that point.
Return of insulating the side attic floor WillK Building & Construction 4 02-06-2011 01:48 PM
in floor heating system and deck mud zantar Flooring 1 07-13-2010 07:50 PM
New Deck Floor 4901 Building & Construction 1 03-10-2010 08:25 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
insulating under first floor NateHanson Building & Construction 19 11-30-2007 11:09 AM
