Insulating 2x6 Rafters?.how To?... - Insulation - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 01:02 AM   #1
insulating 2x6 rafters?.how to?...
in the process of adding a new roof to my shop.the shop is 12 x 14,8ft cement block walls...i went with 2x 6 rafters/24" OC/ridge board in place...i was going to use rolled bats(r-19) between the rafters with bird blocks with holes to allow for air movement,will there be room between the insulation and decking to allow air movement?...would this be okay?...also would i need to add other ventilation like a ridge vent ect?...thx ...
Jeff...
jeffski1 is offline   Reply With Quote
Old 05-02-2011, 01:38 AM   #2
Registered User
Rewards Points: 4,936
The R-19 batt is 6-1/4" thick, no it would not leave a 1-1-1/4" air space. Where are you located-- State?
Have you thought about un-vented? 6' span? How many/size of holes?
Gary
Gary in WA is online now   Reply With Quote
Old 05-02-2011, 02:56 AM   #3
Gary,
located in Tucson Az.very dry area,hot in the summer,high humidity during the monsoon later in summer...im not sure what unvented is?, and i guess i did not do my homework because i thought r-19 batts were smaller in thickness...what do you mean by 6' ft span?...i thought two 1" holes in each birdblock would suffice...thx...
Old 05-03-2011, 10:13 PM   #4
Registered User
Find the Zone; http://publicecodes.citation.com/ico...001_par001.htm
Find the insulation with the Zone; http://publicecodes.citation.com/ico..._11_sec002.htm
Do you have rafters only, no ceiling joists that hold the building/roof from spreading? R-30 is required for your location, need to furr the rafters down to get insulation in with an air space. The 6' is rafter length on each side of ridge. If a low pitch, 2" is suggested for air space above insulation, steeper pitch, 1" minimum. A ridge vent gives 18 NFVA per ft., each side of a gable roof at soffits needs 9 NFVA per ft.; http://www.airvent.com/homeowner/pro...it-specs.shtml
The circular vents are poor with the screens; http://www.lomanco.com/ProductPAGES/CirkVents.html
You'd need three 3+" holes, with screen.
Or go to a conditioned roof; http://www.buildingscience.com/docum...r-all-climates
http://publicecodes.citation.com/ico...006_par003.htm
Gary
Old 05-06-2011, 04:55 AM   #5
Gary
thx for the help...the building itself was not built to code per say...it was built 25yrs ago and we could not find anything on it when we purchased the house...it wont be inspected but of course rebuilding to code(roof,electric) would probably help resale...my shop is only 12x14...2x6 rafters only,8ft cement brick walls,4/12 run/slope for pitch,will be shingled....i guess i didn't plan my insulation install to well...more work to fur out the rafters...Friday i will look for a ridge vent,HD/Lowes does not carry,but a building supplier here in town does...i thought about using a rolled out mesh type vent,any thoughts?......
Jeff
Old 05-06-2011, 07:46 PM   #6
Registered User
Not for me; http://www.inspectapedia.com/interiors/atticcond10.htm
Get the 18 NFVA: http://www.fureyco.com/content/image...ng_The_Air.pdf
Baffled is best: http://files.buildsite.com/dbderived...rived20936.pdf
http://www.oikos.com/esb/30/atticvent.html
DIY: http://www.ehow.com/how_4478641_inst...idge-vent.html
http://www.ronhungarter.com/ridge_vents.html
Gary
Old 05-12-2011, 02:53 AM   #7
Gary,
just getting back...thx for your help......i'm going to try to get to code with the insulation...
Jeff
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
Insulating Below Rafters in 1-1/2 Story House jbeuckm Building & Construction 2 09-29-2010 12:59 PM
Insulating roof rafters in Tenn ? weberus3 Building & Construction 2 10-01-2009 06:36 PM
insulating between rafters - no ridge vent rtoni Building & Construction 3 01-30-2009 05:14 PM
Insulating attic floor AND rafters? John FX General DIY Discussions 11 10-10-2008 11:50 PM
