Insulating A 196 Ranch - Insulation - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 01:05 PM   #1
Rewards Points: 37
insulating a 196 ranch
Hello,
I have a 1965 era ranch in northeast Ohio where it gets somewhat cold and windy, with limited insulation in the exterior walls. I think I have at best 2.0 or 2.5 inch batts in the walls. The master bedroom with three exposed walls is cold(one wall is 20' and two are 10'). It is over a crawlspace and has baseboard heaters.
I am thinking of adding insulation from the outside by taking the vinyl siding and celotex off, adding insulation and replacing the sheating and siding. I have talked to an insulation installer who told me due to the sagging of the old insulation they wont blow insulation int the walls from the outside.
Do I have a reasonable plan or will it be too cost prohibitive
nbmech is offline   Reply With Quote
Old 11-18-2011, 01:24 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
If you are removing the siding/sheathing for the sole purpose of insulating, that is going to be a long term ROI.
What does the attic look like?
You will have more potential savings is proper air sealing and insulating of the attic.
Old 11-18-2011, 07:41 PM   #3
Rewards Points: 37
the attic has close to R40. The room is 65 degrees when the hallway, where the thermostat is located, is 70. Im thinking of adding hot water heat under the floor from the crawlspace to take the chill off before I spend too much money.
Old 11-18-2011, 08:40 PM   #4
Is the crawl conditioned or vented?
Old 11-19-2011, 08:59 AM   #5
Rewards Points: 37
the crawl is unvented, insulated with r13 on the walls and has a poured concrete floor. The temp in there is 67 to 68 degrees now. The bedroom above is 68 at eyelevel ,66 on the floor and the walls are 65. out temp is 46
Old 11-19-2011, 09:54 AM   #6
What does close to R40 mean and in what insulation substrate (Fiberglass, cellulose, etc).
Insulation without air sealing is only addressing about 40% of the problem.
Are the bandboards in the crawl sealed?
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
