Insulating A 1905 Craftsman - Insulation - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 10:01 PM   #1
Insulating a 1905 Craftsman
We tore out the plaster in our kitchen and will be putting up the new drywall soon, what are your recommendations for insulating a home currently without a/c and heat, in Los Angeles? I'm looking for brands as well as any other details I am unaware of. Thanks in advance!
jillers is offline   Reply With Quote
Old 01-22-2012, 10:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Whats the exterior of the home?
Wall Depths, construction type, etc?
Old 01-22-2012, 10:09 PM   #3
Wood siding without sheathing and true 2x4s. I'm not sure what else you need.
Old 01-23-2012, 05:46 AM   #4
Any signs of moisture behind the wood siding?
How insulated are you trying to make the space?
You are climate zone 3 and your insulation/vapor retarder guidelines are relatively lax.
http://publicecodes.citation.com/ico..._11_sec002.htm
Given the fact that your wall is a true 4" wall, you could overstuff a 2x6 wall batt, put 1" foam in the stud bays (pay attention here to the permeability equation) and put fiberglass/mineral wool, etc batt inside of that.
Old 01-27-2012, 09:31 PM   #5
No signs of moisture.
Although we do not have heat or air now, we would like to in the future and don't want to reinsulate at that point.
Old 01-27-2012, 09:38 PM   #6
Rewards Points: 13,712
While it's open do any wiring or adding of outlets. If it's ballon framing make sure to block the bottom and tops of the walls, if the walls over 8ft. tall add block 1/2 way up the wall for a fire block, if there's any wiring or plumbing make sure the oversized holes get filled with expanding foam.
jillers (01-27-2012)
Old 01-27-2012, 10:02 PM   #7
Thanks Joe!
We are in the middle of new electrical and plumbing too. We will make sure to fill holes with expanding foam, and add the fireblocking.
Snowblower: Craftsman vs Poulan wiz561 General DIY Discussions 24 01-31-2015 08:17 PM
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
