Insulated Unfinished Basement (and Concrete Floor?) - Insulation - DIY Chatroom Home Improvement Forum
Old 01-03-2014, 10:50 AM   #1
Rewards Points: 186
Insulated unfinished basement (and concrete floor?)
I have a basement that I'd like to insulate, but I'm not interested in "finishing" it. I'd rather keep the concrete slab and not panel the walls or anything. I'm thinking on using some closed cell spray foam on the walls to put a 1 inch thick layer with an intumescent coating, [url=http://www.youtube.com/watch?v=y7mSlEMbz6s]something like this[/a].
The concrete slab is still pretty huge. In the winter, it's cold; it's a known major source of heat loss ("source of loss"... ugh). It would be nice if I could just slap down 1 inch of ISO at R6.8, pour 4 inches of concrete over it, and have a 5 inch shorter basement with an insulated floor; but, no, that won't work I'm sure. I doubt I could frame it with like... 1 inch high block? Really, tearing the floor up and re-pouring would be better; but that's even more work.
Again, not looking to put in i.e. framing, XPS, a layer of Ditra, and tile; I want an unfinished basement, but an insulated one. If only they had used ICFs in 1920.
If you can't explain why, then you don't know what you're talking about. I'll keep asking until I find someone who does.
bluefoxicy is offline   Reply With Quote
Condensation on concrete floor under basement fiberglass shower/tub insert bsande2 Building & Construction 2 01-22-2012 08:02 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 06:24 PM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 08:28 AM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
