Insulated Bathroom Duct..after The Fact... - Insulation - DIY Chatroom Home Improvement Forum
Old 03-16-2014, 08:12 AM   #1
Rewards Points: 97
Insulated bathroom duct..after the fact...
We have 2 bathroom fans that vent through the attic and out the roof. They are both leaking water through the exhaust fans. I asked this forum and members say that the ductwork needs to be insulated. I'm not sure if its insulated. But if its not can i just wrap insulation (like roofing insulation) around the duct?
edta1 is offline   Reply With Quote
Old 03-16-2014, 08:27 AM   #2
Rewards Points: 14,010
http://www.homedepot.com/p/Master-Fl...RP60/100152008
Old 03-16-2014, 11:04 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
If you have some batt insulation, you can use that as well and cover with something like tyvek to prevent wind washing.
Old 03-16-2014, 03:39 PM   #4
Rewards Points: 30
I would use these 6" duct sleeves. Split them with a utility knife, wrap them loosely around your existing exhaust ducts and tape the seams together with foil tape. If your exhaust ducts are smaller than 6" (4" bath vent, etc.) just overlap the seam slightly when taping the sleeve back together. We use it successfully often.
http://www.homedepot.com/p/Master-Fl...SLV6/100396953
SHR Plumber is offline   Reply With Quote
Bathroom ventilation duct length Didymus21 HVAC 1 12-28-2012 09:42 PM
Duct not providing much heat in upstairs bathroom GimmeShelter64 HVAC 3 12-21-2011 04:00 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Bathroom Fan Duct question bemgolf Building & Construction 12 01-01-2010 05:56 AM
kitchen wall and bathroom fans sharing duct amakarevic Building & Construction 5 06-11-2008 12:13 AM
