Insulate Steel Beam - Insulation - DIY Chatroom Home Improvement Forum
Old 02-08-2014, 05:07 PM   #1
Insulate steel beam
Live in northeast ohio. Bedroom above garage. 2 steel beams run the width of the garage to help support the bedroom above. The beam closest to the garage door is covered with t1-11, and insulation(house wrap..Tyvex?). The interior side of the beam is exposed. Should I insulate this side? Would moisture form on the beam if it is covered with rigid foam?
Thanks for the help.
Revans is offline   Reply With Quote
Old 02-08-2014, 05:19 PM   #2
Rewards Points: 13,274
Got a picture?
Old 02-09-2014, 10:34 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,862
Picture is going to help here.
Steel will likely get colder if insulated but if the insulation is air tight, it will be less likely to form condensate.
Old 02-09-2014, 05:33 PM   #4
Registered User
Rewards Points: 5,216
IMO, if insulated/wood wrapped, the steel will get warmer as it will be keeping more heat from the house (through joist conduction) without garage/outside air wind-washing them, contributing to the heat loss. http://www.buildingscience.com/docum...g%20of%20steel
The joist bottoms should be covered with 5/8" Type X drywall/taped or similar per code minimum, check local AHJ.
Gary
PS. Welcome to the forums!
Column location for LVL Beam Perry401 Building & Construction 1 09-11-2013 12:27 AM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Triple 2x10 beam has twisted WillK Carpentry 11 12-28-2011 12:50 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
steel beam length otto man Building & Construction 4 07-27-2008 09:11 AM
