-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulate steel beam (http://www.diychatroom.com/f103/insulate-steel-beam-195749/)
Revans 02-08-2014 04:07 PM
Insulate steel beam
Live in northeast ohio. Bedroom above garage. 2 steel beams run the width of the garage to help support the bedroom above. The beam closest to the garage door is covered with t1-11, and insulation(house wrap..Tyvex?). The interior side of the beam is exposed. Should I insulate this side? Would moisture form on the beam if it is covered with rigid foam?
Thanks for the help.
joecaption 02-08-2014 04:19 PM
Got a picture?
Windows on Wash 02-09-2014 09:34 AM
Picture is going to help here.
Steel will likely get colder if insulated but if the insulation is air tight, it will be less likely to form condensate.
Gary in WA 02-09-2014 04:33 PM
IMO, if insulated/wood wrapped, the steel will get warmer as it will be keeping more heat from the house (through joist conduction) without garage/outside air wind-washing them, contributing to the heat loss. http://www.buildingscience.com/docum...g%20of%20steel
The joist bottoms should be covered with 5/8" Type X drywall/taped or similar per code minimum, check local AHJ.
Gary
PS. Welcome to the forums!
