-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulate section of basement (http://www.diychatroom.com/f103/insulate-section-basement-168081/)
ejdonnelly21 01-02-2013 08:09 PM
Hello,
I would like to section off of part of my basement where my furnace is located. I would probably block off a 15' x 30' section (assuming this complies with local code). Since our living room is located directly above where the furnace is in the basement, I would like to add insulation to the basement ceiling to try and quite some of the noise when the furnace is running so it's not as loud from upstairs. I know insulating it won't quite it completely, but I figured it wouldn't hurt.
I'm wondering if it would be best to use fiberglass batts or foam insulating boards, or if anyone else had other ideas? I saw some acoustic insulation, which is a little more expensive, but I don't know too much about it.
Thanks,
Ed
Windows on Wash 01-02-2013 10:37 PM
Insulation between the joists will help but you really need to uncouple the noise vibrations via the framing (joists).
Rigid foam covered with a code approved drywall, drop ceiling, and/or rubber isolators will all help considerably.
