Insulate Knee Wall In Cape Cod - Insulation - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 11:53 PM   #1
Insulate knee wall in Cape Cod
Hello, hopefully someone will be able to help me with my renovation of a knee wall in a cape cod style house in Maryland (zone 4). I took some pictures to show you my situation.
The general guidance seems to be that you would insulate the inside wall (#1) of the knee wall and the floor (#4 - the ceiling of the first floor).
The problem I have in my knee wall is that I have plumbing (hot and cold water supply and drain) running in the knee wall (not pictured as it is behind me in the pictures).
As far as ventilation, when I had a new roof put on they put some sort of edge vent. You can see it in this picture:
Due to the plumbing, I'm thinking I should insulate along the roof and the exterior wall. Is this correct? (I started with this premise but on reading some more am worried this may not be right).
To provide a little more information, my roof is only 2x6 rafters and my exterior wall is 2x4. My interior walls are also 2x4. The house will be a rental so not looking to spend crazy amounts of money but want to make it somewhat efficient.
Please let me know if I can provide any other information. The album for all the pictures is located here: http://imgur.com/a/fx6O1
Any help is appreciated!
chimera451 is offline   Reply With Quote
Old 06-03-2013, 06:06 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
If there is plumbing in the kneewall area, the easiest thing to do is to treat it as conditioned space and insulate the roof.
That being said, you will effectively be cutting off the air flow to the upper attic and will need to provide some intake air (roof vents can do this) in order to balance the flow.
Old 06-03-2013, 06:38 AM   #3
Thanks for the reply! The upstairs part of the attic does have ridge venting along the very top. Will that be enough? I've seem some people mention that you need to leave 1" of airspace along the roof in the knee wall. Is that necessary or can I just insulate the whole 2x6 rafters of the roof?
So if I'm treating it as conditioned living space, I'm thinking I'll insulate the roof, exterior wall, and floor (#2, #3, #4 in the picture I posted). I'm thinking the floor to separate the less conditioned knee wall on the second floor from the first floor. Is that correct?
Old 06-07-2013, 10:39 AM   #4
Anyone have any suggestions - really looking for some help so I can get moving on this project!
Old 06-07-2013, 11:16 AM   #5
Handyman
I pretty sure you would want to just insulate the whole 2 x 6 rafters of the roof.. I wouldn't leave a gap. Let us know how the job is progressing!
nicktools561 is offline   Reply With Quote
Old 06-08-2013, 07:55 AM   #6
See below.
I think that might be a mistake.
If you cut off the venting from below, how are you planning on getting intake air into the attic above.
Leave a 2" vent space from the vents you have pictured to the underside of the sheathing and all the way to the upper attic. You can create this via foam board (be sure to cover with code approved ignition and thermal barriers as required).
Old 06-08-2013, 10:48 PM   #7
Registered User
Rewards Points: 5,212
http://www.habitat.org/env/pdf/ceiling_and_attic.pdf
http://oikos.com/esb/51/sideattics.html
http://www.buildingscience.com/docum...n-roof-venting
Gary
Tags
cape cod , insulation , knee wall
Proper construction of shower knee wall lawyer101 Remodeling 2 12-19-2013 09:47 PM
Reframing windows on brick knee wall Mikeymannii2 General DIY Discussions 4 04-01-2013 11:50 AM
Knee wall and rafrer advice Bucky Badger Building & Construction 5 03-07-2011 06:19 PM
Knee Wall Insulation jordan83 Building & Construction 3 09-30-2010 04:48 PM
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 10:14 AM
