Insulate A Garage Door - Insulation - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 08:59 AM   #1
insulate a garage door
would reflectix be a good choice for my eastern facing aluminum garage door? Very conductive in summer, frosts over in winter.
jim Bayless1 is offline   Reply With Quote
Old 01-05-2012, 10:12 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
No.
Doesn't work unless it is over an air space and then, only as a radiant barrier. Not designed as an insulation.
Old 01-05-2012, 10:21 AM   #3
Rewards Points: 13,740
I've used blue foam and attached it with constrution adhesive made for foam panels.
Sometimes it would just not stay stuck so I used starping across the door.
Old 01-05-2012, 03:04 PM   #4
firehawkmph's Avatar
Rewards Points: 1,884
Jim,
your door is more than likely steel. The door manufacturers usually have insulation kits for doors that they sell to convert them from non-insulated to insulated. They consist of precut rectangles, 1 1/2" thick which are made to bow into place in each rectangular recess on the backside of the door. Then there are some L-shaped trim pieces to cover up the edges of the styrofoam with. Look on your door for a manufacturers name and get ahold of that company.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-05-2012, 10:26 PM   #5
Rewards Points: 81
I bought a few sheets of EPS, which is the stuff they make inexpensive ice chests out of.
Much cheaper than the kits. I painted it when I was done.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Garage Door Assistance dukes32 General DIY Discussions 2 06-15-2011 12:11 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Garage Door Install Opinions detailedEye Building & Construction 4 03-31-2010 10:15 PM
Garage Door Questions: closing sides and safety reversal jage Building & Construction 10 11-10-2009 07:57 AM
Garage Door Insulation PaliBob Building & Construction 4 03-27-2009 03:05 PM
