#1 |
Insulate floor on above grade addition
I bought a home in Crownsville, MD that has an above grade addition. Half of the addition is the back portion of my master bedroom and the other half is the master bath. The addition is supported with 6x6's and is roughly four feet above the ground. Our home has forced air heating and our primary heat source is heating oil. Currently I have to run a space heater in the bathroom and bedroom to warm them. I thought of running duct work to the addition but the duct work will be exposed outside and the air would cool before entering the rooms (located about 30 feet (outside) from the heat source). I would like to insulate the underside but was told I risk mold issues because the cool air from inside trying to seep out below the insulation would cause moisture. Is there a vapor barrier I could use? I currently do not have funds to replace the floor and install radiant floor heating.
Are there any options available to me? Thanks, Bill |
#2 |
Exterior Construction
Bill,
There are several options to your scenario that do not create a mold issue or require the removal of the floor for radiant heat. Warm air carries more moisture than cold air and will likely being trying to diffuse to the top side of the home. The easiest solution to your issue is spray foam. You could do rigid foam but that is more time intensive for a more questionable seal if not done perfectly.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Windows on Wash For This Useful Post: | fothrof4 (12-21-2011) |
#3 |
I agree with WOW that spray foam installed from the exterior beneath the floor is the best option.
As for heating: They do make retrofit radiant floor systems that can be applied to the underside of floor sheathing. Though not as efficient as a system applied directly below the floor finish, it still does help. I wouldn't recommend radiant floor heat for rooms with carpeting though, as the padding acts as an insulator and blocks the heat transmissions. An electric retrofit system: http://www.warmzone.com/retrofit-radiant-heat.asp A hydronic retrofit system: http://www.radiantheatreviewer.com/i...ates200185.jpg I couldn't find an actual product for the hydronic, but the pic is what you would want. You'll need the aluminum channels to help distribute the heat energy across the floor system. If you have a large area to heat, I would highly suggest the hydronic system. It is much more efficient than electrical. If you do not have a hydronic boiler, you can add an on-demand heater just to serve this loop.
Life's too short...so enjoy it! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to AGWhitehouse For This Useful Post: | fothrof4 (12-21-2011) |
#4 |
Residential Designer
You mean that your floor has NO insulation whatsoever?
Andy. |
#5 |
| The Following User Says Thank You to Windows on Wash For This Useful Post: | AGWhitehouse (12-21-2011) |
#6 |
Andy,
NONE.....the floor is very cold and the room is extremely cold after a nice hot shower. WOW and Washington, Thank you for the great information. I will do more research on your posts and hopefully get something going soon. Thanks again, Bill |
#7 |
Well if the floor is over a vented crawl space why not just install non-faced, R19 batt insulation?
It is fairly inexpensive and can be done DIY. Andy. |
#8 |
Andy,
The space below is not a crawl space. It is elevated about four feet above ground. My basement door actually exits under the addition. the stairwell goes about halfway and then once at the top of the stairwell you have about short distance before you are out from under the addition. I just stuck some old insulation between the floor joists for now until I find the right way to do it. |
#9 |
Oh yeah, get some fiberglass insulation under that thing.
Not likely to have any condensation problems under there. I would say un-faced and wire it in there. You can probably find individual lengths of wire for this purpose at a building store near you. Andy. |
| The Following User Says Thank You to AndyGump For This Useful Post: | fothrof4 (12-21-2011) |
#10 |
If you are going the fiberglass route be sure to cover it with an air barrier of some kind. Plywood would be best, but tyvek is minimum. Air currents through an un-faced batt will negate almost all of its R-value.
#11 |
AG is probably right, as open as the area is you would be better off with kraft faced or another barrier of some sort as he suggested.
Andy. |
#12 |
Thank you both very much
#13 |
I wouldn't do the kraft faced as that is a Class II vapor retarder and those should only go on the warm side in this application.
#14 |
+1
unfaced batts with tyvek or housewrap barrier. Make sure they are installed tight to the underside and slight over compression on them will ensure they maintain contact with the floor above.
#15 |
Moderator
Faced batts for your area. Housewrap (not a vapor retarder or barrier) on the joist bottoms would still leave you with a floor that insects/rodents could get in, is exposed to the cold ground (radiation factor) and outdoor temperatures with a lot of moisture from the Bay less than two miles away, and could still condense on your framing.
Treat the floor as a wall. I would: 1. air seal any holes going through to the rooms above (to stop the natural stack effect); 2. foam board (2") the rim joists and air seal with canned foam; 3. insulate any HVAC or plumbing pipes; 4. use cellulose or f.g. with a facing vapor retarder, paper, not plastic, held up with wire stays as said; 5. 1-1/2" foam board to the joist bottoms- taped at seams; 6. plywood on foam board with proper length fasteners. http://www.energysavers.gov/your_hom.../mytopic=11480 Find your Zone below the map; http://publicecodes.citation.com/ico...001_par001.htm Find your floor insulation: http://publicecodes.citation.com/ico..._11_sec002.htm R-19= 6-1/4” thick Or stop the ground temp. radiation with foil-faced foam board and f.g. insulation (not held up tight to the floor- figs.6,7). Except where the vinyl bathroom floor is: http://www.buildingscience.com/docum...n-crawlspaces/ http://www.buildingscience.com/docum...-at-rim-joist/ Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Tags |
above ground additions, heating and cooling, insulation ![]() |
| Display Modes | |
| Below Grade Bathroom Addition (Concrete / Flooring Question) | cmremmert | Building & Construction | 1 | 07-12-2011 07:16 AM |
| insulate (mostly) above grade concrete wall | britepepper | Building & Construction | 7 | 06-19-2010 08:39 PM |
| insulate concrete wall above grade? | bcbud3 | Remodeling | 5 | 02-13-2010 07:50 AM |
| Insulating brick above & close to grade | Peter Shepherd | Building & Construction | 1 | 09-16-2009 07:41 AM |
