Insulate Exterior Basement Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 04:51 PM   #1
Insulate exterior basement walls
Hello,
I do not heat my basement, but I would still like to insulate the exposed the cement between the sill and ground.. What is the best way to do this?
So 4 things that I am lookong for..
#1 - I am thinking of using extruded foam board for the insulation.
#2 - What should I use to cover the foam? to weatherize it.
#3 - How should I attach to wall? Liquid nails?
#4 - How deep should I put the foam board etc in the ground?
Thanks,
TobyLLM is offline   Reply With Quote
Old 04-16-2013, 07:28 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,744
XPS is well suited for basement insulation.
If we are talking about exterior applications, you would want to follow the same waterproofing guidelines that you would if it were bare concrete.
Not liquid nails. Use a foam specific glue that will not melt the foam board.
The full depth of the wall.
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 12:36 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Insulate basement walls, 1/2 concrete / 1/2 wood frame rovers1973 Building & Construction 1 04-25-2010 05:50 PM
Insulate Side Walls of Row house acerunner Building & Construction 1 03-27-2010 11:11 AM
Insulate Basement walls?? kimsmash General DIY Discussions 1 03-09-2010 03:03 PM
