Insulate A Cement Floor - Not A Basement Floor - Insulation - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 12:59 PM   #1
insulate a cement floor - not a basement floor
we have just purchased an old home, the last owners added a new addition but only have a subfloor screwed into the cement base, how can we insulate this floor so it will not be so cold. We were thinking of putting Dri Core on top of the existing subfloor?? what is the best cheapest way of insulating before we put down carpet
bonnie scholz is offline   Reply With Quote
Old 04-09-2012, 01:07 PM   #2
Rewards Points: 12,818
Other then treated wood, no form of wood should ever have been installed directly to the slab.
If this floor is dry and above ground what I did was layed blue foam down on the floor (I used 1") and installed 3/4" T X G Advantech subflooring then Tap coned it to the slab.
The floor is now far warmer, it does not move at all and was far cheaper to install then Dri Core.
Old 04-10-2012, 12:25 AM   #3
Registered User
Rewards Points: 4,912
Did you try a "Search" here yet? The white box at top of every page.
Eg- Options for Cold Basement Concrete Floor?
Gary
P.S. Welcome to the forums!
The Following User Says Thank You to Gary in WA For This Useful Post:
KennMacMoragh (04-10-2012)
Old 04-10-2012, 10:46 PM   #4
Rewards Points: 1,092
Depending on your visual preferences and the use of the room, these 2'x2' hard foam pads (sometimes multi-colored) that interlock and are used in kids' play areas, etc, do wonders for improving heat loss through the feet. They are cheap, fast and easy, but if the room is used heavily and constantly, something more skookum may be better.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
painting basement cement floor Ranger31 Painting 11 09-05-2009 05:36 AM
Please Help! Leaky Basement Floor dakotaavenger Flooring 8 04-11-2009 07:36 AM
