Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-11-2012, 03:26 AM   #1
Insulate ceiling
Hello,
I would like to insulate the ceiling of my 4 year old apartment. The ceiling is a flat concrete plate, no false ceiling, no attic, no other choice like to insulate the roof. The only way is to insulate the ceiling from inside my apartment.
I own the apartment and I want it cooler in the summer and warmer in the winter.
Do you have any suggestions?
Thanks.
giannishadj is offline   Reply With Quote
Old 12-11-2012, 09:18 AM   #2
Exterior Construction
Windows on Wash's Avatar
Insulate ceiling
Is there a living space above?
Are you planning on installing a drop ceiling or secondary layer of drywall, etc.?
Old 12-12-2012, 12:55 AM   #3
Insulate ceiling
Hello,
no there is no living space above.
I am planning to install the best solution possible which I do not know which one it is.
Thanks.
Old 12-12-2012, 01:46 AM   #4
Insulate ceiling
Rigid foam is the best in this application but will require being re-covered by drywall for code compliance.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Creating a vaulted ceiling for patio tcaesar1 Building & Construction 1 04-26-2011 11:30 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
