Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 07-21-2011, 11:25 AM   #1
Insulate bottom of bay window
I have a bay window which extends out about one foot from the house. The bottom of it is not insulated. It looks like I could install 1.5" thick foam insulation. 1) Is that the right approach? 2) Would I need to cover the insulation say with exterior plywood or something else?
Thanks for any advice you are willing to offer!
ftcbski is offline   Reply With Quote
Old 07-21-2011, 11:59 AM   #2
Yes it's the right approach, you could even install more if you extend the trim down. It should be covered also exterior plywood or nicer stuff if visible. I see stuff like this all the time even in new houses I work on for some reason most bay windows have little or nothing on the tops and bottoms of them and builders rarely do anything about it
parts is offline   Reply With Quote
Old 07-21-2011, 04:27 PM   #3
Windows & Remodeling
HomeSealed's Avatar
We typically add a 2" piece of XPS (R10) and then bend up some aluminum to dress up the edges... You'll notice a big difference in the temp of the seat board, as well as condensation if that is an issue for you.
HomeSealed is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 05:09 PM
my fix for rotting outside sill on wooden window guest General Discussion 6 11-06-2010 03:58 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
