Insulate Below Grade Family Room - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 05:37 PM   #16
Rewards Points: 1,092
Originally Posted by Windows on Wash View Post
Is there a space between the PT wall or is it tight to the foundation wall?
See above. The PT IS the foundation wall, in my reference. If the PT were inside concrete, I think I'd have the poly outside it, against the concrete, and none inside.
Old 01-25-2012, 06:08 PM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Haven't seen too much of that here in my area.
Do you see much diffusion through through the wood into the wall assembly?
I would use a rigid foam to the PT framing that is Class II vapor retarder so as to allow drying to the inside.
Old 01-25-2012, 07:54 PM   #18
PT basements, I don't think, are that common here anymore, either. I think ICF's have made them obsolete. Were I to build a basement again, like we did w/ my son's a couple of years ago, I'd go w/ ICF's. We built my basement w/ PT wood in '80, and so far it is as dry as a bone. Our soil is fairly dry, as far as I can tell, and I have a serious grade away from the house, plus 3' overhangs on one side and a 12' closed-floor deck on the other side. As always, the best thing to do is to keep water away. In low areas w/ high water tables, I'd not recommend PT in basements, though they may work. I agree w/ drying to the inside.
family room remodel analogmusicman Remodeling 6 08-26-2011 09:10 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 09:19 AM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Renovation a Block Walled Room, Above Grade Douger_F Building & Construction 4 01-06-2009 11:27 AM
