#1 |
Installing XPS foam panels where existing pink bat insulation.
Hi,
I'm planning a basement Reno on a newly built home. Since I've read so much good stuff regarding foam, I'm planning on using it. I think it's called XPS. Thing is, there is already bat insulation on the upper part of the concrete walls. See images. So my question is... Can I use this existing pink insulation and place the foam panels over top? Or do what I suspect and remove it all down to concrete and do a fresh install. I'm also planning on purchasing a tiger foam DIY kit to do the rim joists and hard to reach areas. Any thoughts appreciated, Thanks! Happy reno'ing Siubeer, |
#2 |
Exterior Construction
Where is the home located?
In terms of your questions about re-using the fiberglass and going over top with the foam...yes and no. Technically speaking you could re-used the fiberglass once you have removed the poly that is on top of it, however, you cannot place the foam over top. It would create a double vapor retarder and would not be proper that stand point nor would it be proper and best use of the foam.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Windows on Wash For This Useful Post: | Siubeer (04-17-2012) |
#3 |
The home is North of Toronto Ontario. (Richmond Hill)
I was thinking of using the pink stuff for the ceiling insulation but it makes more sense to put it in the stud wall infront of the XPS. The ceiling I could use Safe and Sound. What would you just use to stick the XPS to the concrete? I've heard people using great stuff spray foam. Would that work well or would it actually push the boards away from the concrete. Thanks! Siubeer. |
#4 |
There are foam specific glues out there that work well.
You also want to think of mechanically bonding to to the foundation wall so that it is not reliant solely on the glue.
| The Following User Says Thank You to Windows on Wash For This Useful Post: | Siubeer (04-18-2012) |
#5 |
Moderator
Odd window height when the outside grade is below the concrete wall...... Remember to change windows for egress if needed and get a permit for the paper trail to satisfy your H.O. Insurance carrier and when you sell.You wouldn't need to insulate the ceiling if basement is heated.
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | Siubeer (04-18-2012) |
#6 | |
Installing XPS foam panels where existing pink bat insulation.Quote:
#7 | |
#8 |
Moderator
Most fire codes require egress-sized window/door from the basement. Most allow a bedroom egress window to serve the basement, no bedroom- egress other than stairs up is required- check locally. Firemen need to enter basement when stairs are burning through an egress window with their oxygen tank on their back; http://docs.google.com/viewer?a=v&q=...33otStRi7Aff7g
No gap: http://joneakes.com/jons-fixit-database/743 Pick affordable; http://www.buildingscience.com/docum...study-analysis Home court; http://www.buildingscience.com/docum...Insulation.pdf Gary
| The Following User Says Thank You to Gary in WA For This Useful Post: | Siubeer (04-26-2012) |
#9 |
-- Basements [with habitable space] req escape & rescue
opening ………………………………………………….… [310.1] Dang, are you serious? Then any finished basement in the neighbourhood would need their windows resized... That's nutz. Gotta call the city tomorrow. "habitable" means capable of being lived in. Is a basement with rec room and wash room considered habitable? I'm thinking that means you have a suite with bedroom. Last edited by Siubeer; 04-26-2012 at 01:26 AM. |
#10 | |
#11 |
that is my understanding. the thinking is : if people are down there drinking beer (or whatever). they can see the fire and run out. but if people are down there sleeping. they won't see that the stairs are on fire, until it is too late. then they need another way out.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#12 |
Moderator
Most all (as far as I know) require "emergency escape and rescue OPENING from basements, habitable attics and sleeping rooms:http://publicecodes.citation.com/ico...?bu2=undefined
"HABITABLE SPACE. A space in a building for living, sleeping, eating or cooking. Bathrooms, toilet rooms, closets, halls, storage or utility spaces and similar areas are not considered habitable spaces. " Gary
#13 |
If it passed code at the time, you are likely grandfather'ed in.
If you are going to finish the basement now, easier to do it properly now and only trim the window once.
#14 |
Moderator
Many times the builder installs a smaller (cheaper) window with the "unfinished" basement at sale. It doesn't require egress size until finishing, that is when you bring the space up-to-code. So what did the Building Inspector/Fire Department say?
Gary
| Display Modes | |
| Spray foam insulation | troyce1 | Building & Construction | 9 | 05-24-2011 07:57 PM |
| Foam and Elastomeric coats over existing BUR ???? | sunguy65 | Roofing/Siding | 2 | 02-25-2011 01:48 PM |
| Existing Cathedral Ceiling Insulation Question | Bob Deb | Building & Construction | 8 | 12-07-2010 08:54 PM |
| Exterior Foam Insulation Help??? | teachtech | Building & Construction | 3 | 11-29-2008 11:19 AM |
| Installing new insulation in my basement and removing the old moldy insulation. | Fixitgeorge | Remodeling | 3 | 10-17-2006 09:33 PM |
