Installing Tyvek Barrier From Inside Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 04:04 PM   #1
Installing tyvek barrier from inside walls
I have a 1901 Victorian located in the San Joaquin valley of California and slowly I'm removing the lathe and plaster and redoing everything from new electrical to plumbing. While the walls are open I'm putting in fire blocking to my balloon framed home and I also want t insulation. My question is if I need to use tyvek paper and if so which way does face and do I do it only in between wall studs? Or wrap studs too. Any help would be greatly appreciated.
butterkups is offline   Reply With Quote
Old 01-06-2013, 04:12 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,168
Not really. The Tyvek will help with keep the insulation less friable and help with the air barrier.
You don't need it though. Be sure to blocker everything off like you are doing and seal everything that you can to make it as air tight as possible.
Old 01-06-2013, 04:24 PM   #3
Thanks.
So would I put wrap, tyvek printed side facing to the exterior and tack it to the wall studs, then place my insulation, then my drywall? Or would it just be simpler to get insulation batts already with a vapor barrier.
Here we get lots of fog during the winter and from late dec thru feb it gets below 30 at night and high 40s low 50s during day. Our cars always have lots of moisture on windshield. Just trying to keep my walls from sweating too much.
Oh, I have redwood ship board siding.
Old 01-06-2013, 05:07 PM   #4
Rewards Points: 13,300
If there's no sheathing and just siding attached to the studs I would if it was mine.
I'd also add fire blocking at the top and bottom of the wall.
Old 01-06-2013, 05:21 PM   #5
Does not matter which way it faces.
House wrap will still let the house breath, will only keep out beads of water, but will stop air from leaking in from any gaps in the siding.
butterkups (01-06-2013)
Old 01-06-2013, 05:55 PM   #6
Thanks for the quick feedback.
Would I wrap the studs too and staple paper to the studs and then tape the seams? Followed by my r19 insulation batts then drywall.
Old 01-06-2013, 11:18 PM   #7
Registered User
Rewards Points: 5,266
I merged your two threads with the same question.
The paper facing on insulation is a vapor retarder, not required for your location, check with local AHJ. I say this because science backs it up; you are in Zone 3; http://www.buildingscience.com/docum...commendations/
Yet CA has it's own Energy Code, depends on location; http://www.energy.ca.gov/maps/renewa...ate_zones.html
Under the CA Code; http://publicecodes.cyberregs.com/st...ch8_sec001.htm
The Tyvek can be an air barrier (if perfectly air sealed around the edges/complete perimeter) and weather resistant barrier. Be aware, with a wood siding right after a rain on the sunny side, you could easily get solar gain, wetting the siding back-side and HW. As the moisture wicks to the housewrap and drains down -- wetting the wood sill plate unless you installed the HW; lapping over bottom plate by removing the bottom siding course first (on a slab). This would be similar to proper installation, minus the inset attachment rather than exterior faces of studs.
Gary
Old 01-07-2013, 09:26 AM   #8
Can you post up a picture of the interior wall?
Depending on what you have got, you can create some unintended issues.
Old 01-07-2013, 12:15 PM   #9
Here is exterior wall.
Old 01-08-2013, 01:16 AM   #10
Rewards Points: 626
Originally Posted by butterkups View Post
Thanks.
the tyvex goes on the out side of the home between the sheething and siding!
Nailbags is offline   Reply With Quote
Old 01-08-2013, 09:11 AM   #11
Attachment 63216
Good picture. Do you see moisture infiltration anywhere?
Can you provide a picture of the exterior.
The cut and cobble method would probably work here but you need to know if there is any leaks first before you potentially change how the wall can dry.
The original poster was thinking of it in terms of an air barrier.
Frost inside exterior walls in basement kanesdaddy Building & Construction 21 12-30-2012 09:02 AM
using OSB to finish inside walls Linds Building & Construction 3 11-12-2010 10:53 AM
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls myhouse2010 Building & Construction 1 10-18-2010 12:35 AM
Installing insulation and vapor barrier to exterior basement walls Fernando Sinn Building & Construction 11 04-11-2008 12:11 PM
