Installing Radiant Barrier In Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 06:44 AM   #1
Rewards Points: 150
Installing radiant barrier in attic
I bought a two 100x4' rolls of radiant barrier to install in the attic of my two story garage. The plan is to install the barrier in the pockets between joists.
My question is what do I do with the roofing nails sticking through the sheathing? They protrude about 1/2" - have to be careful as I've come close to impaling myself on them a time or two. Is it ok that the barrier is punctured by these nails?
In case it's asked, I live in Atlanta. The barrier is going in the whole garage, but mainly for the south facing roof (which already generates a LOT of heat).
sheslostcontrol is offline   Reply With Quote
Old 04-18-2011, 04:07 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I've never seen any radiant barrier that should be installed that way. I assume that since it is a garage, there is not an insulated attic floor? Check manufacturer instructions or search for a diy guide or video, but based on what you've said so far, it should go on the underside of the roof rafters, not between them. It should be continuous.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-19-2011, 07:31 AM   #3
When you install a radiant barrier you should fasten it to the roof joists just below the roof surface (not the attic floor) using a staple gun. The small channel between the joists will allow hot air to escape thru your ridge vent, etc. Don't let your attic get hot when you can avoid it.
Deckmaster is offline   Reply With Quote
Old 11-23-2011, 07:47 AM   #4
Hey sheslostcontrol, did you complete this project? The way you described doing it would be wrong, so I hope you listened to the other posters!
carlosc is offline   Reply With Quote
Old 11-23-2011, 08:51 AM   #5
Rewards Points: 150
Hi I did it just the way the guy above explained. It made a huge difference.
Old 11-23-2011, 09:04 AM   #6
Very happy to hear that!!! Post pics if you can.
Cheers
Carlos
Old 11-23-2011, 09:14 AM   #7
Rewards Points: 150
I just did let me know if you can't see it.
Old 11-23-2011, 09:24 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Pics are there.
What are you doing with that space that you need to take the heat down?
Old 11-23-2011, 09:36 AM   #9
Rewards Points: 150
The upstairs is a finished office and music studio area. I don't have any A/C yet but hope to get a mini split installed sometime in the future.
Old 11-23-2011, 12:24 PM   #10
Okay.
Radiant barriers do have applications in some cases when controlling heat gain from the roof, but they are never a substitute for a proper insulation layer.
Old 11-23-2011, 12:29 PM   #11
Rewards Points: 150
That's why I had insulation installed beforehand.
I also insulated the exterior (and interior) walls to help with heat loss and soundproofing. Used cotton batt insulation.
Old 11-23-2011, 01:04 PM   #12
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I am curious as to what your location is.
South west states, California, Arizona, Nevada?
Andy.
AndyGump is offline   Reply With Quote
Old 11-23-2011, 02:20 PM   #13
Rewards Points: 150
Georgia
Do the radiant barriers work in the attic? imola ghost Green Home Improvement 13 09-08-2011 10:13 PM
removing roof supports in attic, installing a room denemante Building & Construction 4 01-24-2011 08:51 PM
Insulation and Radiant Barrier Titans Roofing/Siding 6 06-22-2010 10:46 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Installing an attic above my 2 car garage jdavid Carpentry 2 07-17-2008 11:50 AM
