Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 07-10-2011, 11:50 AM   #1
installing foam board
When installing 3/4" foam board over existing and or repaired wall sheathing (1/2" plywood & fiberboard) should I tape all of the seems before the housewrap? Or would this trap moisture from escaping through the wrap?
mmason is offline   Reply With Quote
Old 07-13-2011, 10:00 PM   #2
Moderator
Welcome to the forum!
Depends on if the foam board or the house wrap is the air barrier: http://www.greenbuildingadvisor.com/...s-housewrap-go
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Minimum foam board thickness over OSB Arky217 Building & Construction 3 01-11-2011 11:13 PM
fire barrier for foam board insulation jcomp Building & Construction 1 12-12-2010 08:03 AM
Question regarding Housewrap and Foam board insulation psychomti Building & Construction 16 10-27-2010 09:50 PM
House wrap over insulating foam board or under?? getn2old Building & Construction 7 07-28-2010 11:53 PM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 09:17 PM
