Installing Ceiling Over Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-17-2014, 02:03 PM   #1
Installing ceiling over insulation
I've removed the 12 x 12 tiles and the old insulation in the garage ceiling. The 1 x 1s that held the tiles are still there. I can get the bat insulation through them and they hole it in place. My question is, Should I removed the 1 x 1 so that the insulation is tight with the drywall ceiling? Also, has anyone here used Guardian Insulation? It's half the cost of Owens Corning.
Joe Goots is offline   Reply With Quote
Old 03-17-2014, 06:56 PM   #2
Rewards Points: 13,260
Why would you not be installing it from above the old ceiling?
It needs to be stapled in place to pull it tight to the joist not just resting on the 1X's.
Old 03-17-2014, 07:27 PM   #3
I am placing the facing against the bedroom floor (garage ceiling) as a vapor barrier. I am then covering the garage ceiling with fire resistant sheetrock.
Installing Ceiling Fan Electrical Box (Old Construction) jtslue24 Electrical 7 09-16-2012 01:58 PM
Installing Ceiling Medallion Twister Remodeling 6 05-14-2011 08:39 AM
Installing upper cabinets when ceiling is not level bhuck Carpentry 7 07-31-2010 10:21 PM
concrete slurry ceiling insulation? mwools Roofing/Siding 6 04-03-2010 05:39 PM
Adding insulation to the underside of a high ceiling churchlady Building & Construction 6 11-17-2009 08:02 PM
