Installing Batts Around Can Lights - Insulation - DIY Chatroom Home Improvement Forum
Old 11-24-2014, 10:50 PM   #1
liscenced electrician
Rewards Points: 538
installing batts around can lights
I am insulating some new construction with r-38 batts. The can lights are rated for contact with the insulation. What is the right way to go about it? I can't seem to find any information. Only thing I can find is information on going in to attics and insulating existing construction
jimmy21 is offline   Reply With Quote
Old 11-24-2014, 11:07 PM   #2
Rewards Points: 2,084
The batts just touch the can, around the fixture, just make sure that the paper facing if there is any does not touch the housing, and do not cover the fixture entirely, the heat has to escape.
ED
de-nagorg is online now   Reply With Quote
Old 11-24-2014, 11:13 PM   #3
Rewards Points: 538
Yes. Its going to be Kraft faced, so that's what I was really wondering about. So I basically just cut the insulation batt where the can light starts and then start another batt after the can light? There isn't going to be much heat in the can lights. I installed enough of them that it is excessively bright in the room with only 15 watt cfl lamps in each one. 15 watt CFLs barely even get warm.
Old 11-24-2014, 11:17 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,744
Is this a cathedral ceiling? If so, you really need to box them out with airtight covers.
Old 11-24-2014, 11:18 PM   #5
Rewards Points: 538
No. Its just a flat 8' ceiling with attic space above.
Old 11-25-2014, 08:30 AM   #6
I would still box them out. Better safe than sorry and insulation contact rated does not equal airtight.
installing a motion sensor switch for two seperate lights. Roundeye Electrical 9 11-03-2013 06:18 AM
installing exterior Motion Sensor lights DWS0802 Electrical 6 11-08-2012 10:31 AM
Installing to motion sensor lights KENNEDYCHIEFS34 Electrical 1 08-22-2011 07:50 AM
installing recessed lights, entertainment center overload? fabian Electrical 5 01-13-2010 12:25 PM
Installing Recessed Lights IdahoBob Electrical 6 08-23-2007 10:03 PM
