Installing Baffles - Insulation - DIY Chatroom Home Improvement Forum
Old 03-04-2014, 02:58 AM   #1
Installing baffles
Hello new to the forum I'm getting ready to start adding insulation to my attic
As of right no there are no baffles above the sofit vents so I want to add them the house is a 1200 sq ft ranch I have 6 sofit vents and a ridge vent do I only need to add baffles above those vents or add them on every rafter or every other?
The attic has 6 inches of blown insulation which is slim for the Midwest climate I'm in
262markm is offline   Reply With Quote
Old 03-04-2014, 05:07 AM   #2
Rewards Points: 13,750
#1, Adding your location to your profile is a big help with questions like this.
Just go to quick links to edit.
#2, You do not have enough soffit venting.
http://www.todayshomeowner.com/adding-soffit-vents/
#3, Here's a guide to the min. amounts of insulation you should have.
http://www.energystar.gov/index.cfm?...sulation_table
#4, Make sure to air seal any place wiring, plumbing, and ceiling fixtures run into the attic with spray foam before adding more insulation.
Old 03-04-2014, 05:31 AM   #3
The sofit style is maintenance free aluminum with holes in it so I would imagine it is a open style sofit? I cant just cut holes add to it like wood sofit or can I? Also as in seal the attic basically make sure I have no heat loss from lighting fixtures and bathroom venting otherwise I won't see the full affect of the added insulation? How many baffles need to be added
Old 03-04-2014, 06:22 AM   #4
When you look in the attic can you see light where those vents are.
Here's my concern, way to many times I've seen where they installed the vented soffit but never even made any holes or cutout for the venting in the plywood behind it.
There's several ways more venting can be added.
The coil stock can be removed without damage by tapping in the trim nails with a nail set, then remove some of the solid and replace with vented.
Round snap in vents could be added between the ones you already have.
And last Smart vents could be added.
http://www.dciproducts.com/html/smartvent.htm
Old 03-04-2014, 06:25 AM   #5
Ok ill look into that And post back
Old 03-04-2014, 11:15 PM   #6
Registered User
Rewards Points: 5,516
Distance between roof sheeting/exterior wall; height?
Air sealing; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Baffle every bay.
Gary
PS. Welcome to the forums!
Baffles... installed upside down? Sansui Roofing/Siding 13 05-27-2013 07:15 AM
Installing pre-formed shower base pan svaic00 Plumbing 4 05-22-2013 07:08 PM
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 02:21 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
