Injecting Spray Foam Insulation Into A 2' Cut Out Section Of Basement Drywall. - Insulation - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 11:27 AM   #1
injecting spray foam insulation into a 2' cut out section of basement drywall.
Could I put spray foam insulation into the approximate 2' cavity at the bottom of my (recently cut-out due to flooding) basement drywall) when there are already 6' pink batts above? Is it possible to combine the two? If so, would I then need just need to seal the existing, visible vapour barrier and, if so, with what?
spuds65 is offline   Reply With Quote
Old 09-10-2011, 08:39 PM   #2
Registered User
Rewards Points: 526
Welcome to the forum!
You should use rigid foam board on the walls against the concrete wall. Perhaps you are in Canada? The vapor barrier gave it away...http://www.buildingscience.com/docum...gs?full_view=1
If the fiberglass got wet, replace it all; http://www.inspectapedia.com/sickhou...rglassMold.htm
Gary
Old 09-13-2011, 05:04 PM   #3
Gary
But why can't I just spray foam into that space and into the gap behind the set back 2x4s ( for the 6" batts)?
Old 09-14-2011, 09:37 PM   #4
Registered User
Rewards Points: 526
Go for it. You really shouldn't have a poly vapor barrier in a basement unless in certain areas of Canada or AK. http://libdspace.uwaterloo.ca/bitstr...c%20Thesis.pdf
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
spuds65 (09-15-2011), wilsonstark (09-26-2011)
Old 09-15-2011, 08:15 PM   #5
Thanks for that.......a wealth of highly technical info, too technical for me, i'm afraid.
I am leaving all of this for a month (or longer).
Upon my return I may first get a backflow valve installed and then have the foundation waterproofed-another issue indeed-if weather permits. Or, I may just leave the whole thing until the spring to see if I get any more water into the basement.
Unfortunately, I have to pay to get these things done, I just don't have the knowhow or the tools.
Old 09-15-2011, 10:07 PM   #6
Registered User
Rewards Points: 526
I understand, that money thing hits me too....
Gary
Tags
foam insulation
Spray foam for basement? ctote Insulation 0 07-20-2011 07:57 AM
Info on spray in foam insulation Alcarte General DIY Discussions 3 01-30-2011 08:03 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Basement and Foil-Faced Foam Insulation Help emlinjr Building & Construction 3 09-17-2008 02:51 PM
