-   Insulation (http://www.diychatroom.com/f103/)
-   -   injecting spray foam insulation into a 2' cut out section of basement drywall. (http://www.diychatroom.com/f103/injecting-spray-foam-insulation-into-2-cut-out-section-basement-drywall-116831/)
spuds65 09-10-2011 11:27 AM
Could I put spray foam insulation into the approximate 2' cavity at the bottom of my (recently cut-out due to flooding) basement drywall) when there are already 6' pink batts above? Is it possible to combine the two? If so, would I then need just need to seal the existing, visible vapour barrier and, if so, with what?
Gary in WA 09-10-2011 08:39 PM
Welcome to the forum!
You should use rigid foam board on the walls against the concrete wall. Perhaps you are in Canada? The vapor barrier gave it away...http://www.buildingscience.com/docum...gs?full_view=1
If the fiberglass got wet, replace it all; http://www.inspectapedia.com/sickhou...rglassMold.htm
Gary
spuds65 09-13-2011 05:04 PM
Gary
But why can't I just spray foam into that space and into the gap behind the set back 2x4s ( for the 6" batts)?
Gary in WA 09-14-2011 09:37 PM
Go for it. You really shouldn't have a poly vapor barrier in a basement unless in certain areas of Canada or AK. http://libdspace.uwaterloo.ca/bitstr...c%20Thesis.pdf
Gary
spuds65 09-15-2011 08:15 PM
Thanks for that.......a wealth of highly technical info, too technical for me, i'm afraid.
I am leaving all of this for a month (or longer).
Upon my return I may first get a backflow valve installed and then have the foundation waterproofed-another issue indeed-if weather permits. Or, I may just leave the whole thing until the spring to see if I get any more water into the basement.
Unfortunately, I have to pay to get these things done, I just don't have the knowhow or the tools.
Gary in WA 09-15-2011 10:07 PM
I understand, that money thing hits me too....
Gary
